eCart add to cart button not working right
Thread begun 1/08/2010 6:25 am by canonman208475 | Last modified 1/08/2010 10:40 am by Jimmy Wu | 1476 views | 2 replies |
canonman208475
When I tried to add to cart pg 29-31 of tutorial it doesn't work correctly. In the bindings tab when I click Name....and then Lightning Bolt I get the following.....
Setup Instructions
To use Dynamic Data on this page:
1 Create a site for this file
2 choose a document type
3 Set up the sites testing server
4 Create a recordset
I already setup rsItems. Something must be missing in download.
Please help
canonman208475
add to cart button not working correctly
I am using php
Jimmy Wu
Are there checkmarks next to any of these steps? Which step is the one that doesn't have a check mark next to it?
Also, you should check out our learning resources page:
resources.php
Specifically Defining a Dynamic Site in Dreamweaver, setting up a testing server, and Creating your database connection in Dreamweaver tutorials. If you follow those tutorials, you should be able to set up the site and pages correctly.
