Product options that effect price
Thread begun 1/07/2010 10:23 pm by stuff223820 | Last modified 1/08/2010 11:57 am by Jimmy Wu | 1960 views | 3 replies |
stuff223820
Ok, i have found a couple of places in the forum that address this a little but i am still stumped.
I want to sell photographs. I want to have them select from the options drop down, a set size from 3 possible sizes. Each size will be a different cost. Ex: 8x10=$50 16x20=$100, etc.
Products_Detail.php?ProductID=10
I can not figure out how to do that. I see a version of it in the eCart manual, pg 148, but the titles they are using as selections in the recordset panel reference the BlueSky sample store. For my table selection in the recordset window, do i choose "productoptions" or "optiongroups" ?
Is there another walk through somewhere else that i am missing?
If i do all this, in the recordset control panel, how do i get it to my server? is this new variables show up on a page or do i have to generate a new database somehow?
Jimmy Wu
You will not have to make any modifications on the PowerStore to get different priced options to work.
When you are either adding a new product or editing an existing one, you will want to click on the add/edit Options button at the top if you are editing or check the add product options checkbox at the bottom if you are adding a new product. Once on that page you can add an option (for your example, something like size) and then add values (the different sizes). After you are done with this, you should click on the "Click Here To Manage Options" button to make the ones you want to be shown on the live web page live. You can also edit the stock here as well. To change the price of a specific option, you will have to go to the edit product page. With the option drop down select the one you want and change the price for it. If you want them all to be updated to the same price, you can click the update all options checkbox next to the Price box.
stuff223820
man - that was an easy fix!! thanks a ton.
I tried everything to get it figured out last night - but that was so simple..
Jimmy Wu
No problem. Glad you were able to get it working. If you run into any additional issues, feel free to open a new thread.
