USPS Rate Lookup API Failure
Thread begun 1/07/2010 6:32 pm by lazyhoofer376912 | Last modified 1/14/2010 6:51 pm by Eric Mittman | 8781 views | 9 replies |
lazyhoofer376912Beta Tester
Hopefully you all can help me with the below issue. I have a PowerStore 2 site setup with USPS Rate Lookup and Authorize.net charge card access.
I've run into an issue with the Rate Lookup specifically where I attempt to checkout and I have the Rate Lookup activated, I'm bumped to the Checkout Failure page. If I disable the Rate Lookup, my site works fine and I can process payments.
I've contacted USPS and they've advised me that I am on the LIVE servers. Below is a snipet from my GLOBAL code and also the e-mail received from USPS.
Global:
// USPS Shipping Settings
$WAGLOBAL_USPS_User = "xxxxxxxx1314"; // get this when you sign up for API access
$WAGLOBAL_USPS_Server = "http://production.shippingapis.com/ShippingAPI.dll"; // change this to the live server when you go live
$WAGLOBAL_USPS_ShipType = "FIRST CLASS"; //Enter the appropriate value for domestic shipping, based on the USPS Shipping key at the bottom of this page.
$WAGLOBAL_USPS_IntShipType = "Global Express Mail (EMS)"; //Enter the appropriate value for shipping to international customers, based on the USPS Shipping key at the bottom of this page.
E-mail 1:
"Thank you for registering for the U. S. Postal Service's Web Tools
Application Program Interfaces (APIs). We are providing you with a
User ID that serves multiple purposes, as explained below.
Your Username is xxxxxxxx1314
Your Password is xxxxxxxxD745
Your Web Tools User ID, shown above, is required to test and integrate
USPS Web Tools APIs. With this ID, you may begin sending calls to the
test server. Depending on the API, the address to the test server is
either ShippingAPITest.dll or
ShippingAPITest.dll. Use this
information in combination with your User ID and your XML string to
send a request to the USPS servers. For more details, refer to the
programming guides (located at webtools) for the
specific API you are integrating."
E-mail 2:
"Congratulations on completing your testing using the U.S. Postal
Service's Web Tools Application Program Interfaces (APIs). Your
profile has been updated to allow you access to the Production Servers.
The URLs you will use for the Production Servers are:
ShippingAPI.dll
ShippingAPI.dll
Profiles that are inactive for four years will be permanently deleted
without notice."
Thanks for the help!
You will need to put the bindings for the full request and full response on the checkout failure page to see what is causing the error. Here is the code you will need to put on this page, you just insert this code where you would like to see the information appear on that page:
full request
<?php echo $_SESSION["WA_Store_Cart_USPS_FullRequest"]; ?>
full response
<?php echo $_SESSION["WA_Store_Cart_USPS_FullResponse"]; ?>
USPS Rate Lookup API Failure! Please Help
So i put the code into the page and this is what i got....
API=RateV3&XML=FIRST CLASSFIRST CLASS117351111102REGULAR -2147219085Rate_Respond.;SOLServerRates.RateV3_RespondInvalid XML Element content is invalid according to the DTD/Schema. Expecting: FirstClassMailType, ZipOrigination. line= 0 pos= 12371000440
how do i go about fixing this?
This seems similar to another issue that was discovered with the way the xml is sent. If you can please post back and include a copy of your WA_eCart folder in a zip archive so I can take a look at your USPS pages to determine if this is a related issue.
thank you so much for helping out with this.
It looks like the file did not get uploaded to the post. You will need to first add the WA_eCart folder from your site root to a zip archive. Once it is in a zip file you can the upload the zip with your reply. I will examine the files to try and find where the problem is coming from.
uploaded zip
heres the zip file. sry about b4 thought it sent.
Please give this a try with this WA_eCart_USPS_PHP.php file and let us know if it solves the problem for you. This file goes inside of your WA_eCart folder in your site.
so i replaced the file with what you gave me and it said this now.....
API=RateV3&XML=FIRST CLASS117351173502REGULAR -2147219428DomesticRatesV3;clsRateV3.ValidateFirstClassMailType;RateEngineV3.ProcessRequestInvalid First Class Mail Type.1000440
I have opened a new ticket for you on this issue. To check the status or update the ticket please login to WebAssist.com and visit your support history.
