connection to MySQL with Data Assist possible?
Thread begun 1/07/2010 11:42 am by jcarello269587 | Last modified 1/07/2010 11:57 am by Jason Byrnes | 1964 views | 2 replies |
jcarello269587
Hi
I am new to PHP and MySQL. I went into the control panel on my host and set up a mysql database. They have PHPmyadmin running on the server.
When I go to the main screen, the host is telling me this:
Your MySQL databases are stored behind a firewall to protect your data. You can only access each one exclusively through your server. Direct access to your MySQL databases using a home PC (external ODBC connection) cannot be established.
My question: am I going to be able to use Data Assist or not?
Thanks!
Jennifer
Office Guy-172461
Yes that's fairly standard. It just means that your website can access the database on the same server, but they don't want programs on outside servers to access the database.
In this case, you will need a local testing server with PHP and MySQL set up on your loacl computer for testing.
Create the database on the your local MySQL server to develop using using Dreamweaver and DataAssist.
When you upload the files to the remote server, you will only need to update the connection file settings so that it will use the copy of the database on the remote mySQL server instead.
See our learning resources page:
resources.php
for tutorial on setting up a local testing server and configuring a dynamic site in Dreamweaver.
