If a user double clicks the add or insert button on an insert/update form it adds two
Thread begun 1/07/2010 10:34 am by neil.batchelor254136 | Last modified 9/08/2020 8:34 am by Ray Borduin | 8730 views | 17 replies |
If a user double clicks the add or insert button on an insert/update form it adds two records, one if often incomplete.
Some of my users are not that intelligent, how can I prevent the double record add or update and just allow one click please?
I should say that if the user clicks on the add or update form once it is perfect.
So how do I prevent the stupid double click from causing bad records or problems.
Thanks,
Neil
Jimmy Wu
You can set the onclick to disable the button after it is clicked once, thus preventing the 2nd click also submitting the form. There are some examples of what you can try using javascript that can be found if you do a web search. Here's one of them:
disable-button-after-first-click/
no double click on submit
Thanks Jimmy but none of that worked??
Instead I put this in the form action:
<form action="EATING_PLACES_Insert.php" method="post" name="WADAInsertForm" id="WADAInsertForm" onsubmit="if (formCheck(this)) { this.elements['Insert'].disabled=true; } else { return false; }">
but this doesn't work either!!???
Does anyone have any ideas please?
Plus how do I string together onsubmit events, it is ok like this:
<form action="LISTINGS_Insert.php" method="post" name="WADAInsertForm" id="WADAInsertForm" onsubmit="if (formCheck(this)) { this.elements['Insert'].disabled=true; } else { return false; }
&& (using the && to link onsubmit)
WAValidateEL(document.getElementById('WADAInsertForm').VENUE_NAME,document.getElementById('WADAInsertForm').VENUE_NAME.value,'Your Venue Name has an invalid number of characters in entry. The maximum allows is 250 characters.',1,250,'',document.getElementById('WADAInsertForm').VENUE_NAME,0,true);WAValidateEM(document.getElementById('WADAInsertForm').GENERAL_EMAIL,document.getElementById('WADAInsertForm').GENERAL_EMAIL.value,'The general email input is not valid. Please reenter using a real email address.',document.getElementById('WADAInsertForm').GENERAL_EMAIL,0,false);WAValidateEM(document.getElementById('WADAInsertForm').GM_EMAIL,document.getElementById('WADAInsertForm').GM_EMAIL.value,'The general manager email input is not valid. Please reenter using a real email address.',document.getElementById('WADAInsertForm').GM_EMAIL,0,false);WAValidateEM(document.getElementById('WADAInsertForm').DIR_SALES_EMAIL,document.getElementById('WADAInsertForm').DIR_SALES_EMAIL.value,'The Sales Director email input is not valid. Please reenter using a real email address.',document.getElementById('WADAInsertForm').DIR_SALES_EMAIL,0,false);WAValidateEM(document.getElementById('WADAInsertForm').CB_MGR_EMAIL,document.getElementById('WADAInsertForm').CB_MGR_EMAIL.value,'The C&B manager email input is not valid. Please reenter using a real email address.',document.getElementById('WADAInsertForm').CB_MGR_EMAIL,0,false);WAValidateEM(document.getElementById('WADAInsertForm').CB_CONTACT_EMAIL,document.getElementById('WADAInsertForm').CB_CONTACT_EMAIL.value,'The C&B contact email input is not valid. Please reenter using a real email address.',document.getElementById('WADAInsertForm').CB_CONTACT_EMAIL,0,false);WAValidateEL(document.getElementById('WADAInsertForm').NEAREST_LANDMARK,document.getElementById('WADAInsertForm').NEAREST_LANDMARK.value,'- Invalid number of characters in entry Nearest Landmark (maximum two thousand characters allowed)',0,2000,'',document.getElementById('WADAInsertForm').NEAREST_LANDMARK,0,false);WAValidateEL(document.getElementById('WADAInsertForm').SEARCH_PREF,document.getElementById('WADAInsertForm').SEARCH_PREF.value,'There is an invalid number of characters in entry search preference (maximum two thousand characters allowed)',0,2000,'',document.getElementById('WADAInsertForm').SEARCH_PREF,0,false);WAValidateEL(document.getElementById('WADAInsertForm').PARK_DESC,document.getElementById('WADAInsertForm').PARK_DESC.value,'There is an invalid number of characters in entry park description (maximum two thousand characters allowed)',0,2000,'',document.getElementById('WADAInsertForm').PARK_DESC,0,false);WAValidateDT(document.getElementById('WADAInsertForm').INSERT_DATE,'- You have an invalid insert date. The format has to be yyyy/mm/dd',true,/\b\d{4}\/(1[0-2]|0[1-9])\/([12]\d|3[0-1]|0[1-9])\b/,'yyyy/mm/dd','','',false,/.*/,'','','',document.getElementById('WADAInsertForm').INSERT_DATE,0,true);WAAlertErrors('The following errors were found','Correct invalid entries to continue please',true,document.getElementById('false'),false);WAValidateEL(document.getElementById('WADAInsertForm').LOCATION_DESC,document.getElementById('WADAInsertForm').LOCATION_DESC.value,'There is an invalid number of characters in entry location description (maximum two thousand characters allowed)',0,2000,'',document.getElementById('WADAInsertForm').LOCATION_DESC,0,false);WAValidateEL(document.getElementById('WADAInsertForm').GM_DESC,document.getElementById('WADAInsertForm').GM_DESC.value,'There is an invalid number of characters in entry GM Description(maximum two thousand characters allowed)',0,2000,'',document.getElementById('WADAInsertForm').GM_DESC,0,false);WAValidateNM(document.getElementById('WADAInsertForm').PARK_NMBR_SPACES,'The field with the number of parking spaces is invalid.',0,1000000000000,'','','',',.',document.getElementById('WADAInsertForm').PARK_NMBR_SPACES,0,false);WAValidateEL(document.getElementById('WADAInsertForm').CB_DESC,document.getElementById('WADAInsertForm').CB_DESC.value,'There is an invalid number of characters in entry CB description (maximum two thousand characters allowed)',0,2000,'',document.getElementById('WADAInsertForm').CB_DESC,0,false);return document.MM_returnValue">
Jimmy Wu
Try setting the onclick event like this:
onClick="disabled=true;this.form.submit();return true;"
I found that information here:
t-28560.html
As well as a method to use the onsubmit for the form and setting the onsubmit function to not do anything the second time it is submitted.
No double click
Sorry Jimmy I dont have much faith in this because:
One post says:
Working on some other problem, I found a solution to it. I added the following attribuut to the submit button:
and another says:
Do not use submit button, but form onsubmit event.
<form onsubmit="return verifyData(this)" ...
function verifyData(myForm)
{ /* Do your data verification here */
/* If everything is ok and you are ready to submit */
myForm.onsubmit = function()
{ alert('How about some patience, huh? ;^)');
return false;
return true;
fredmv
02-24-2004, 05:46 PM
Do not use submit button, but form onsubmit event.Completely correct; can't believe I didn't think of that.
So I am totally confused on what to use and exactly how to implement it.
Thanks,
Neil
Jimmy Wu
There were two different methods proposed for accomplishing the prevention of the double click. The first one being to put the code into the submit button:
The second was to apply changes to the form onsubmit. The second method would change the onsubmit function so that if it is clicked on the second time it would alert a message instead of submitting the form. You can change the message to something more fitting to your form, like "Please do not double click the submit button".
These both look like valid solutions to this issue.
restrict user double click the submit button
Jimmy and any other help,
I still haven't found a solution that works. I would really like a step by step idiots guide to restrict user double click the submit button.
Many thanks,
Neil
Jimmy Wu
Can you send me a page with the code applied so I can take a look at it?
Thomas Hill
Prevent user double clicking
Hi I've been looking around for a solution to preventing a user from double clicking a button on a form, and therefore submitting duplicate entries to the database.
The thread here does not show a final solution and I wondered if there was one?
I've attached my page for you to look at, since I am completely lost as to how to implement it.
Tom
hide the submit button on click.
change:
<input name="Add_New_Ticket" type="image" id="Add_New_Ticket" value="Add_New_Ticket" src="../images/add.png" alt="Add_New_Ticket" hspace="0" vspace="0" border="0"  />
<input name="Add_New_Ticket" type="image" id="Add_New_Ticket" value="Add_New_Ticket" src="../images/add.png" alt="Add_New_Ticket" hspace="0" vspace="0" border="0"  onClick="this.style.visibility = 'hidden';" />
