localhost vs. remote server
Thread begun 1/07/2010 4:12 am by chris396479 | Last modified 1/08/2010 1:08 pm by Office Guy-172461 | 5235 views | 5 replies |
chris396479
Trying to follow instructions...I have attempted to use a static address in the 'From' tab and the 'to tab' and failed to sumbit the form - something I am not 'getting' here.
I have a localhost PHP/MySQL to test the site - can this work with the extension or is that not possible due to the fact its on the localhost (me) and not actually live? Therefore the site must be live to work.... its logical captain... (?)
I managed to import the free MySQL tables from WebAssist - would it help if I communicated with that? (after putting data in the table - with recordsets I presume).
Anyone who manages to get this up and running on the first, second or third attempt deserves a medal for reading between the lines or its just I have a very little brain!
If I get this to work I'll think I'm Einstein! (For sure!)
Office Guy-172461
Don't forget that you need a working email server to send email. That might be the difference between remote and local.
See:
How to set up a local testing server for Dreamweaver
144/
You don't say what you are trying to do or the errors you're getting.
chris396479
loclhost/email server set-up
Thanks for the link (I have read/printed off the info).
I am connected to a MySQL database on my localhost which is where the 'working email server' should be... but its not 'Powerstore' just the blank tables from WebAssist... its no good blank nes pa, so I will need to make a recordset?
I loaded the form and got no errors so that says it all! The Submit button did not work or at least had no code or something elementary like that.
I have gone through the tutorials in DWCS3 The Missing Manual more than once and I have discovered I'm thicker than I thought!
However, I will persevere and re-do the tutorials - it looks like I am missing the program to process the form so I will have to design that next - I think!? Would you concur sir!
Talk about confusing!
Office Guy-172461
There is no default email server in a local environment. You have to install it if you want one. I test all of my email related routines on my web server because I don't want an email server running on my local machine.
I'm still not sure what you are trying to do, but if you want a simple contact form you would:
  1. Create a form
  2. Use Universal Email to send the contents by email
If you want to store the contents of the form in a database, you would then use one of the databases from WA or create your own.
PHP is what is used to process the the code. Apache is what processes the standard html. MySQL is the database for storing data.
chris396479
Thankyou for your patience and insight. Excellent concise definitions.
So, I create ANY form with Form Builder extension (which are all different designs of CONTACT form right?) - then I 'configure the form to send email' - so the contents (on the most basic level) are simply sent by email, to an email address, with no crunching in a database... aaaahhh... and as you say the testing can only be done properly on the live web server itself.
You say databases from WA - how many types are there from WA? I am attempting (cough) to head in the direction of - prepare yourself - eCommerce - eCart territory so the ducks need to be in line.
Thanks for your time!
Office Guy-172461
Contact Solution form was created by Form Builder.
Have a look here:
tutorials-and-training/
Take a look at:
eCommerce mySQL Database
and
Database Starter Kit for PHP (a free video tutorial)
