Not sending to addresses within the same domain
Thread begun 1/06/2010 2:07 pm by sandy259886 | Last modified 1/07/2010 2:36 pm by sandy259886 | 2726 views | 4 replies |
sandy259886
My order process sends several order confirmation emails. about 4 to domains other than the store domain ... those all send fine. However, the copies that go to the same domain name as the store, disappear. What's up with that?
When the email sends to some domains, but not others, it points to a setting on the SMTP server that is preventing it from relaying emails to that domain.
This can also happen if the From and To address are the same. Double check that the email address you are trying to send the email to is not the same as the email address being used for the From Address. If these two are different, then contact the host to see if they can look into the smtp servers error logs to see why it is refusing to relay.
sandy259886
server requires authentication
The smtp server requires authentication. How do I do that with Universal Email?
If you are using PHP, select the PEAR Mail for SMTP Mail Object, this will allow you to pass authentication to the SMTP server.
sandy259886
I'll try that
Thanks. I'll try that and see what happens.
