Problem getting Universal Email to send anything.
Thread began 1/06/2010 7:52 am by jajja | Last modified 1/06/2010 12:22 pm by jajja | 1671 views | 4 replies |
jajja
I can't get Universal email to send any mail from a site I've made. I have used Universal Email several times before, sometimes with problems of this kind, sometimes not, but now I'm stuck.
The mail is to be sent in conjunction with eCart, sending the order to the store owner.
I have tried "everything", made the checkout procedure over from scratch several times, read these forums and so on but still no mail get's sent nor do I get any error message.
I have attached the files as a zip file.
Thanks.
ue_problem.zip
on the tilattu_ok.php page, you have the universal email behavior set to trigger on the checkout button being pressed.
The checkout page will not trigger this because the checkout form action is to post to itself:
<form action="" method="post" >
it then redirects to the tilattu_ok.php, change the forms action to post to the tilattu_ok.php page instead:
<form action="tilattu_ok.php" method="post" >
jajja
This was my initial setup. Tried changing it now again as you wrote but no, nothing is sent nor do it give me any error.
you are setting the from address to come from hidden_e_post element, it does not look like this will yield a valid email address:
<input name="hidden_e_post" type="hidden" value="<?php if(isset($_SESSION['kt_e-post'])){ echo "Sähköposti: " . $_SESSION['kt_e-post'] . "<br>" ;}?>">
the from email address must be a valid email address
jajja
Of course! Oh man you saved my day (night). Thanks a million times!
