IE8 Search Problem
Thread begun 1/05/2010 4:38 pm by B Tonkin | Last modified 1/06/2010 7:48 pm by Eric Mittman | 6577 views | 8 replies |
B Tonkin
IE8 Search Problem
Just testing out my PowerStore2 site on IE8 and have noticed an issue when doing a search. Chrome, Safari and Firefox, on both OSX and Windows, works a treat, but when doing a search on IE8 it seems to be dropping the necessary "Search=Search" section of the URL. Without it it just seems to be repeating the first search.
Products_Results.php?Search=Search&S_ProductName=ITEMNAME works.
Products_Results.php?S_ProductName=ITEMNAME doesn't work.
I have done some testing on my local PowerStore in IE 8, I also tried this with compatibility mode on. In my testing the search parameter was always showing up in the URL. Do you have a link to your site where we can try this out? Please post back with a link some test search terms that you are using when you experience this problem. I will do some testing to see what results I get and let you know what I discover.
B Tonkin
Buy Wine Online
The site is ... www.buywineonline.com.au/ ... do a search for something (like sparkling) and then try another search for something else (like rose). On IE8 it seems to be displaying results from the initial search.
I have done some testing on your site and this is not the result that I get when I use IE 8 or any other browser.
In my first search I looked for 'bor' and found 53 results. For my follow up test I went to the search page and looked for 'ter' and this found 166 results. When I examine the URL in both of these cases I can see the search parameter present and set to search.
I'm including some screen shots from my test for your reference. It seems that there may be something else to this as I'm not getting the same result when I test it.
B Tonkin
Nav or Search Page?
Was that a search from the nav bar or from the search page? For me the search page works good, but from the nav bar it doesn't. Same problem on IE7 and IE8.
B Tonkin
Nav Bar vs Search Page
Nav bar form looks like this ...
<form id="searchForm" method="get" action="Products_Results.php" >
<input type="text" name="S_ProductName" id="S_ProductName" />
<input name="Search" type="submit" id="Search" value="Search" alt="Search" />
</form>
... and the search page form looks like this ...
<div class="contentBox">
<form action="Products_Results.php" method="get" name="WADASearchForm" id="WADASearchForm" class="WADADataTable">
<fieldset class="insertForm">
<p>
<label for="S_ProductName">Keyword:</label>
<input type="text" name="S_ProductName" id="S_ProductName2" value="<?php echo((isset($_GET["S_ProductName"]))?$_GET["S_ProductName"]:"") ?>" size="32" />
</p>
<p>
<label for="S_ProductPrice">Price Range:</label>
<span id="sprytextfield1">
<input type="text" name="S_ProductPrice" id="S_ProductPrice" value="<?php echo((isset($_GET["S_ProductPrice"]))?$_GET["S_ProductPrice"]:"") ?>" size="10" onblur="if (document.getElementById('priceRangeServerValidation')) document.getElementById('priceRangeServerValidation').style.display='none';" style="width: 114px;" />
</span> -
<span id="sprytextfield2">
<input name="S_ProductPrice2" type="text" id="S_ProductPrice2" onblur="if (document.getElementById('priceRangeServerValidation')) document.getElementById('priceRangeServerValidation').style.display='none';" value="<?php echo((isset($_GET["S_ProductPrice2"]))?$_GET["S_ProductPrice2"]:"") ?>" size="10" style="width: 114px;" />
</span><span id="additionalErrorZone" class="additionalErrorZone"><span class="textfieldRequiredMsg textfieldInvalidFormatMsg textfieldMinCharsMsg textfieldMaxCharsMsg textfieldMinValueMsg textfieldMaxValueMsg">Price range fields can be positive numbers, or left blank.</span></span>
if (ValidatedField("ProductsResults","ProductsResults")) {
if ((strpos((",".ValidatedField("ProductsResults","ProductsResults").","), "," . "1" . ",") !== false || "1" == "") || (strpos((",".ValidatedField("ProductsResults","ProductsResults").","), "," . "2" . ",") !== false || "2" == "")) {
if (!(false)) {
<span class="textfieldServerError" id="priceRangeServerValidation">
</span>
<?php //WAFV_Conditional Products_Results.php ProductsResults(1,2:)
</p>
<div class="buttons">
<input name="Search" type="submit" id="Search2" onclick="if (document.getElementById('priceRangeServerValidation')) document.getElementById('priceRangeServerValidation').style.display='none';" value="Search" />
<input type="submit" name="cancel" id="cancel" value="Cancel" onclick="window.location = 'Products_Results.php';" />
</div>
</fieldset>
</form>
</div>
... what have I done wrong?
That was it! When I test the search from the nav bar and use the enter key to submit the form it will not include the search parameter in the URL.
To fix this you will need to go into the Templates > Main.dwt.php file. Go into split view and select the submit button in the nav bar. In the code you will need to update this submit button to look like this:
html:
<input name="Search2" type="submit" value="Search" id="Search" alt="Search" />
Then you need to add in a hidden form element to this form, it can be before this submit button or just after it, here is the hidden form element you will need to add:
html:
<input type="hidden" name="Search" value="Search" />
This is a problem in IE, if you use the enter key to submit a form it will not always submit what is in the value attribute of the submit button. Changing the name of the submit button to be search2 then adding a new hidden form element with the name search and a value of search will fix this.
If you encounter this problem in the future this is a pretty good workaround for it. I will make sure that a bug is logged for this issue. Thanks for being so patient and working this out with me.
B Tonkin
Worked a treat
Thanks for that. Worked a treat. Always love a logged bug.
Thanks again for being so patient on this, good catch.
