Link to email confirmation page does not work
Thread begun 1/05/2010 4:02 pm by di5856 | Last modified 1/07/2010 2:25 pm by di5856 | 1892 views | 2 replies |
di5856
After registering I receive an email with the following:
Please follow the link below in order to verify this email address:
users_Confirm.php?ID=4&code=vjAESa1qKFJ2tzxF4CIy
I click the link, and get the following message:
Page Not Found
We cannot locate the page you're looking for. Please check the address and make sure all letters are lowercased with no spaces. You may also move to a different page by using the links in the menu bar above.
The URL in the Address line of my browser is:
What do I have to do to correct this?
Thanks!
make sure the $WAGLOBAL_Root_URL in the WA_Globals file is set correctly.
the $WAGLOBAL_Root_URL should go to the root of the directory you have uploaded the user registration solution pack.
If the user registration solution pack file are uploaded to:
userReg
the root url needs to be set to:
$WAGLOBAL_Root_URL = "http://www.yourdomain.com/userReg/" ;
di5856
I did have the paths wrong. When I copied the folder into Dreamweaver, I let it update the links - big mistake! It caused all of my problems. I deleted my folder and copied in the original folder again without updating the links. I input my systme info, and everything worked beautifully!
THANKS!
