Recreating the update page?
Thread begun 1/05/2010 10:28 am by Brad Lawryk | Last modified 1/06/2010 7:20 am by Brad Lawryk | 1755 views | 3 replies |
Brad Lawryk
Is there a way to recreate the Update page only?
For some reason my update page got messed up ... no idea why. It was working fine and I was updating records then all of a sudden it started doing really wierd things and does not update properly any more.
Brad
sure, the first step of the wizard allows you to choose which pages to create. The results page cannot be deselected, so set the name for the results page to some thing off the wall so it wont overwrite the existing results page, the deselect all others except the update page.
Brad Lawryk
Thanks Jason,
Just a note for others on this .. you have to delete your old file that you are replacing. I didn't delete it on first try and it just added the code to the old update form leaving two forms on the same page.
Brad
Brad Lawryk
Another thing that must be done if you use this method is that two places in the code you have to change the redirect page back to your original Results page. The code inserys your fake redirect page as the page it should redirect to.
