SQL error trying to access recordset
Thread begun 1/05/2010 5:21 am by robert329616 | Last modified 2/09/2010 3:34 pm by Jason Byrnes | 13660 views | 10 replies |
robert329616
Hello,
I am having an issue trying to access the recordset on the Products_Results.php page. The errror is:
MySQL Error#: 1064
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '' at line 2
I am running the latest version of MAMP with the latest sql and PHP so I am not sure why I am getting this.
I would like to access the recordset so I can try to modify it for cross selling products.
Thanks.
Regards,
Rob
The recordset on the Products_Results.php page is to complex for Dreamweaver to process.
The only way you will be able to edit that recordset is directly in the code, you will not be able to edit it using the Dreamweaver interface.
robert329616
OK.
Thanks Jason.
Rob
Paul
Jason,
I just posted a question on this...should have searched first.
If it is too complex for Dreamweaver to process, how do I add the ProductID field directly above the WADAProducts.ProductPrice field in the Products_Detail.php page?
I'm using Options, and would like the customer to see which Item # they are looking at when the select a different option.
Here is the code (I put the words "ProductID Here" to show you where I would like it to go):
I would also like to make the Options field wider if possible. It is too short to see all the info.
<div id="addFields" <?php echo(($row_WADAProducts["NumLeft"] > 0 || $row_WADAProducts["ProductUnlimited"] != 0)?'':'style="display:none"'); ?> >
<input type="hidden" name="WA_Store_Cart_1_ID_Add" id="WA_Store_Cart_1_ID_Add" value="<?php echo $row_WADAProducts["ProductID"]; ?>" />
ProductID Here
<h2 id="ProductPrice">$<?php echo number_format($row_WADAProducts["ProductPrice"], 2); ?></h2>
<input type="image" src="Images/btn_addtocart.png" border="0" value="Add to Cart" name="WA_Store_Cart_1_ATC" align="absmiddle" />
<label>Qty:</label>
<input type="text" name="WA_Store_Cart_1_Quantity_Add" value="1" size="2" align="absmiddle" />
<br />
<a href="#"><img src="Images/btn_learnmore.png" width="111" height="22" alt="Learn More" style=" margin-top: 4px;" /></a>
</div>
use:
to output the product ID to the page.
Paul
And if I wanted to show the Category below the product name, is it this?
<?php echo $row_WADAProducts['ProductCategory']; ?>
No, use:
<?php echo $row_WADAProducts["CategoryName"]; ?>
Paul
Jason,
It is not showing anything.
Here's the link: Products_Results.php
Learn More about any of the products. You'll see that above the price I put:
Category:
Item #:
The item # shows up, but not the category.
Not sure why, but the item number field has single quotes around the field name PRODUCTSKU: Item #:&nbsp;<?php echo $row_WADAProducts['ProductSKU']; ?>
But the CategoryName has double quotes.
Change the sql for the WADAProducts recordset from:
$query_WADAProducts = sprintf("SELECT * , (ProductStock - (SELECT Coalesce(Sum(DetailQuantity),0) FROM orderdetails INNER JOIN orders ON OrderID = DetailOrderID WHERE DetailProductID = ProductID AND OrderDate > ProductUpdateDate))*ProductLive AS NumLeft FROM products  WHERE ProductID = %s OR ( -1= %s AND ProductID= %s)", GetSQLValueString($ParamProductID_WADAProducts, "int"),GetSQLValueString($ParamProductID2_WADAProducts, "int"),GetSQLValueString($ParamSessionProductID_WADAProducts, "int"));
$query_WADAProducts = sprintf("SELECT *, (ProductStock - (SELECT Coalesce(Sum(DetailQuantity),0) FROM orderdetails INNER JOIN orders ON OrderID = DetailOrderID WHERE DetailProductID = ProductID AND OrderDate > ProductUpdateDate)) AS NumLeft, (SELECT MAX(ProductPrice) FROM products as prod2 INNER JOIN productoptions ON productoptions.ProductID = prod2.ProductID WHERE  productoptions.GroupingID = products.ProductID AND prod2.ProductLive <> 0) AS TopPrice, (SELECT MIN(ProductPrice) FROM products as prod2 INNER JOIN productoptions ON productoptions.ProductID = prod2.ProductID WHERE productoptions.GroupingID = products.ProductID AND prod2.ProductLive <> 0) AS BottomPrice FROM products  LEFT OUTER JOIN productcategories ON ProductCategoryID = CategoryID  WHERE ProductID = %s OR ( -1= %s AND ProductID= %s)", GetSQLValueString($ParamProductID_WADAProducts, "int"),GetSQLValueString($ParamProductID2_WADAProducts, "int"),GetSQLValueString($ParamSessionProductID_WADAProducts, "int"));
Paul
Thanks, Jason!
That worked.
The only thing is the Item # doesn't change when you select a different option. Even when a person has multiple items in the cart.php page, it shows the same item # for all of the items.
Paul
