Database Required?
Thread begun 1/05/2010 3:34 am by andrew372225 | Last modified 1/05/2010 9:30 am by Jason Byrnes | 1743 views | 2 replies |
andrew372225
Database Required?
I've just purchased Digital File Pro in the hopes that I would have a simple file upload solution. However I cannot get it to work and wonder if I need to have a database. If so can anyone point me to some help on how to set one up for Digital File Pro and what I need to do.
Brad Lawryk
Hi Andrew,
What is it you are trying to do?
Brad
If all you are trying to do is simply upload files, then there is no need for a database.
Here are some things to double check if File upload is not working:
1) To be able to upload a file, the forms encoding type must be set to multipart/form-data. Dreamweaver will do this for you automatically if you add the file field by going to Insert -> Form -> File Field. If you add the file field manually, you will need to change the encoding type.
2) Make sure the forms method is set to post, you cannot upload a file using the GET method.
Here is an example form:
<form  action="" method="post" enctype="multipart/form-data" name="form1">
  <label for="fileField">File:</label>
  <input type="file" name="fileField" id="fileField">
  <br>
  <label for="button"></label>
  <input type="submit" name="button" id="button" value="Submit">
</form>
