Uploading images - add new product
Thread begun 1/04/2010 4:19 am by ben_bradley348417 | Last modified 1/05/2010 11:48 am by Eric Mittman | 3351 views | 3 replies |
ben_bradley348417
I've setup the rest of my site on powerstore v2, and i've just come to testing adding a new product, and I think its something to do with the images.
Do the 2 images options have to be different image sizes?
I've altered the permissions that Jason has recommended and this is still occuring below, i've also added some php in the products insert.php page, but that came up with a (function - start) hyperlink at the top of the page. So, i've put it back to how it was.
Here's the error im getting;
Warning: move_uploaded_file(/home/users/uks47018/html/frockonvintage.co.uk/Admin/../Images/Upload/0b9cdf0a8d235d9f1dd5ac977306f61a_tmp.jpg) [function.move-uploaded-file]: failed to open stream: Permission denied in /home/users/uks47018/html/frockonvintage.co.uk/WA_DigitalFilePro/HelperPHP.php on line 96
Warning: move_uploaded_file() [function.move-uploaded-file]: Unable to move '/tmp/phpYMWQqW' to '/home/users/uks47018/html/frockonvintage.co.uk/Admin/../Images/Upload/0b9cdf0a8d235d9f1dd5ac977306f61a_tmp.jpg' in /home/users/uks47018/html/frockonvintage.co.uk/WA_DigitalFilePro/HelperPHP.php on line 96
Warning: copy() [function.copy]: Unable to access /home/users/uks47018/html/frockonvintage.co.uk/Admin/../Images/Upload/0b9cdf0a8d235d9f1dd5ac977306f61a_tmp.jpg in /home/users/uks47018/html/frockonvintage.co.uk/WA_DigitalFilePro/HelperPHP.php on line 98
Warning: copy(/home/users/uks47018/html/frockonvintage.co.uk/Admin/../Images/Upload/0b9cdf0a8d235d9f1dd5ac977306f61a_tmp.jpg) [function.copy]: failed to open stream: Permission denied in /home/users/uks47018/html/frockonvintage.co.uk/WA_DigitalFilePro/HelperPHP.php on line 98
Warning: move_uploaded_file(/home/users/uks47018/html/frockonvintage.co.uk/Admin/../Images/Upload/c5ad12d08c4b127d0fb371befc12aaf6_tmp.jpg) [function.move-uploaded-file]: failed to open stream: Permission denied in /home/users/uks47018/html/frockonvintage.co.uk/WA_DigitalFilePro/HelperPHP.php on line 96
Warning: move_uploaded_file() [function.move-uploaded-file]: Unable to move '/tmp/phpNkZbuW' to '/home/users/uks47018/html/frockonvintage.co.uk/Admin/../Images/Upload/c5ad12d08c4b127d0fb371befc12aaf6_tmp.jpg' in /home/users/uks47018/html/frockonvintage.co.uk/WA_DigitalFilePro/HelperPHP.php on line 96
Warning: copy() [function.copy]: Unable to access /home/users/uks47018/html/frockonvintage.co.uk/Admin/../Images/Upload/c5ad12d08c4b127d0fb371befc12aaf6_tmp.jpg in /home/users/uks47018/html/frockonvintage.co.uk/WA_DigitalFilePro/HelperPHP.php on line 98
Warning: copy(/home/users/uks47018/html/frockonvintage.co.uk/Admin/../Images/Upload/c5ad12d08c4b127d0fb371befc12aaf6_tmp.jpg) [function.copy]: failed to open stream: Permission denied in /home/users/uks47018/html/frockonvintage.co.uk/WA_DigitalFilePro/HelperPHP.php on line 98
Warning: Cannot modify header information - headers already sent by (output started at /home/users/uks47018/html/frockonvintage.co.uk/WA_DigitalFilePro/HelperPHP.php:96) in /home/users/uks47018/html/frockonvintage.co.uk/WA_ValidationToolkit/WAVT_Scripts_PHP.php on line 71
This looks to be permissions issue you are having with the directories involved. It seems that you are not able to move the temporary uploaded file to the desired directory.
You should take a look at the permissions you have on the Images/Upload directory, also you should ensure that you have read and write permissions for the temp directory as well, /tmp/.
ben_bradley348417
Hi Eric,
I've already made the images folders permissions - owner read, write, and execute, and just read & write for the other 2. But this still brings up the same error messages.
Where is the /tmp/ folder?
Is this a directory problem?
This is definitely a directory issue you are encountering. The temp directory looks like it is just off of the root at /tmp. You will probably not have access to this directory, you should contact your host to see if you can get access to this directory or have them adjust the permissions for you.
If you have the proper permissions for both directories involved, the tmp and the upload directory then you should not get this error message. Along with the upload folder you should check on the folder that it is contained in to ensure that there are not conflicting permissions.
