Data Assist Wizard Error
Thread began 1/04/2010 3:03 am by colby393170 | Last modified 1/04/2010 12:01 pm by Jimmy Wu | 1210 views | 1 replies |
colby393170
When entering the Key column, it errors in this field: MM_ERROR: An unidentified error has occurred.
I've searched the forum, checked MySQL db, everything I can think of. I've ran this before and had no problem. Is this a cache issue?
Running on a Mac.
Jimmy Wu
Have you installed any updates since you last had the wizard working? Try deleting the cache file and see if that helps with the issue.
