Error message
Thread begun 1/03/2010 12:32 pm by Roxana | Last modified 1/03/2010 7:30 pm by Roxana | 2208 views | 3 replies |
Roxana
Error message
at the end of the index page there is an error message displayed in the browser:
Warning: mysql_free_result(): supplied argument is not a valid MySQL result resource in /var/www/html/www.name.eu/web/index.php on line 164
The code of line 163-165 is:
mysql_free_result($Recordset1);
Despite the error message the page works fine.
Deleting the code lines 163 to 165 got rid of the error message. My question is, is it OK to delete the code? Or will this lead to problem?
Thanks for any help
Roxana
Roxana
Maybe I should mention, that there is no recordset "Recordset1" on the page.
anonymous
Hi Roxana,
There would be no danger in deleting the code. That code simply would free the result if the recordset actually existed. But since you said there is no recordset on that page by the name - that makes the code trying to free the result to become invalid, nonetheless - which will cause the problem you are describing.
Technically, you don't have to free the result ever (except in cases where a query may be reused over and over). But the main reason it is done is to flush the query from the PHP server memory and allow for more efficient applications, so it is good practice (and also the reason DW automatically generates a free result command whenever a recordset is created).
Warmest regards and Happy New Year,
Brian
Roxana
Hi Brian,
Thank you for helping me out. I do rely heavily on DW to write most of the code for me. And I usually don't touch any of that code. There are a few more pages that have the same lines of code at the end with no recordset to go with. So I will clean those pages up as well.
Thanks again and Happy New Year
Roxana
