Add to Cart Javascript error
Thread begun 1/03/2010 10:47 am by georgina_barrett_187762 | Last modified 1/08/2010 3:44 pm by Jason Byrnes | 5765 views | 5 replies |
I am trying to add a Add to Cart button but when I go to select a recordset I get a pop up saying While executing onClick in WA eCart AddToCart.htm, a JavaScript error occurred. After searching the forums I have tried deleting the winfilecache - but I still have the problem.
Before adding the add to cart button, make sure the connection to the database is working and test the recordet.
Go to Window -> Bindings to open the Bindings panel, click the plus symbol next to the recordset to show the columns, does this generate a MySQL Error?
If so double check the database connection, go to Window -> Databases to open the database panel. Double click your connection. In the edit connection dialog box, click the test button to test the connection.
If the connection tests OK, please post back with the mySQL Error form the first test and a copy of your page.
The recordset is fine I don't get any errors when opening it.
I am trying to add the button here: <div class="WADAResultCommerceButton"></div>
I have attached a screenshot of the error and the file.
what happens if you simplify the recordset code from:
$colname_WADAtyres = "-1";
if (isset($_POST['S_width'])) {
  $colname_WADAtyres = (get_magic_quotes_gpc()) ? $_POST['S_width'] : addslashes($_POST['S_width']);
$colname5_WADAtyres = "-1";
if (isset($_POST['S_runflat'])) {
  $colname5_WADAtyres = (get_magic_quotes_gpc()) ? $_POST['S_runflat'] : addslashes($_POST['S_runflat']);
$colname3_WADAtyres = "-1";
if (isset($_POST['S_load'])) {
  $colname3_WADAtyres = (get_magic_quotes_gpc()) ? $_POST['S_load'] : addslashes($_POST['S_load']);
$colname4_WADAtyres = "-1";
if (isset($_POST['S_speed'])) {
  $colname4_WADAtyres = (get_magic_quotes_gpc()) ? $_POST['S_speed'] : addslashes($_POST['S_speed']);
$colname1_WADAtyres = "-1";
if (isset($_POST['S_depth'])) {
  $colname1_WADAtyres = (get_magic_quotes_gpc()) ? $_POST['S_depth'] : addslashes($_POST['S_depth']);
$colname2_WADAtyres = "-1";
if (isset($_POST['S_size'])) {
  $colname2_WADAtyres = (get_magic_quotes_gpc()) ? $_POST['S_size'] : addslashes($_POST['S_size']);
mysql_select_db($database_connect, $connect);
$query_WADAtyres = sprintf("SELECT * FROM tyres WHERE tyres.sale >0 AND tyres.width = %s AND tyres.`depth` = %s AND tyres.`size`= %s AND tyres.speed LIKE %s AND tyres.load LIKE %s AND tyres.runflat >= %s", GetSQLValueString($colname_WADAtyres, "int"),GetSQLValueString($colname1_WADAtyres, "int"),GetSQLValueString($colname2_WADAtyres, "text"),GetSQLValueString("%" . $colname4_WADAtyres . "%", "text"),GetSQLValueString("%" . $colname3_WADAtyres . "%", "text"),GetSQLValueString($colname5_WADAtyres, "text"));
$WADAtyres = mysql_query($query_WADAtyres, $connect) or die(mysql_error());
$row_WADAtyres = mysql_fetch_assoc($WADAtyres);
$totalRows_WADAtyres = mysql_num_rows($WADAtyres);
$query_WADAtyres = "SELECT * FROM tyres";
the try to add the add to cart button? After adding the add to cart button, you can revert the recordset code to the original.
That did allow me to add the 'add to cart' button. However when I upload the file and click the add to cart button it doesn't go to the shopping cart it redirects back to the same page.
This is the head code
//WA eCart Include
require_once("WA_eCart/eCart1_PHP.php");
$eCart1->GetContent();
<?php require_once('Connections/connect.php'); ?>
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
$theValue = ($theValue != "") ? "'" . doubleval($theValue) . "'" : "NULL";
break;
case "date":
break;
case "defined":
break;
return $theValue;
$query_depth = "SELECT DISTINCT tyres.`depth` FROM tyres ORDER BY tyres.`depth`";
$depth = mysql_query($query_depth, $connect) or die(mysql_error());
$row_depth = mysql_fetch_assoc($depth);
$totalRows_depth = mysql_num_rows($depth);
$query_size = "SELECT DISTINCT tyres.`size` FROM tyres ORDER BY tyres.`size`";
$size = mysql_query($query_size, $connect) or die(mysql_error());
$row_size = mysql_fetch_assoc($size);
$totalRows_size = mysql_num_rows($size);
$query_load = "SELECT DISTINCT tyres.load FROM tyres ORDER BY tyres.load";
$load = mysql_query($query_load, $connect) or die(mysql_error());
$row_load = mysql_fetch_assoc($load);
$totalRows_load = mysql_num_rows($load);
$query_speed = "SELECT DISTINCT tyres.speed FROM tyres ORDER BY tyres.speed";
$speed = mysql_query($query_speed, $connect) or die(mysql_error());
$row_speed = mysql_fetch_assoc($speed);
$totalRows_speed = mysql_num_rows($speed);
$query_width = "SELECT DISTINCT width FROM tyres ORDER BY width ASC";
$width = mysql_query($query_width, $connect) or die(mysql_error());
$row_width = mysql_fetch_assoc($width);
$totalRows_width = mysql_num_rows($width);
// WA eCart AddToCart
if (isset($_POST["eCart1_1_ATC"]) || isset($_POST["eCart1_1_ATC_x"])) {
$ATC_itemID = $_POST["eCart1_1_ID_Add"];
$ATC_AddIfIn = 0;
$ATC_RedirectAfter = "shoppingcart.php";
$ATC_RedirectIfIn = "";
if (isset($totalRows_WADAtyres) && $totalRows_WADAtyres > 0) {
$row_WADAtyres = WAEC_findRecordMySQL($WADAtyres, "tyresID", $ATC_itemID);
if ($row_WADAtyres) {
$ATC_itemName = "".$row_WADAtyres['name'] ."";// column binding
$ATC_itemDescription = "".$row_WADAtyres['width'] ."/".$row_WADAtyres['depth'] ." ".$row_WADAtyres['size'] ."";// column binding
$ATC_itemWeight = floatval("0");// column binding
$ATC_itemQuantity = "".$_POST["eCart1_1_Quantity_Add"] ."";// column binding
$ATC_itemPrice = floatval("".$row_WADAtyres['sale'] ."");// column binding
$ATC_itemMake = "".$row_WADAtyres['make'] ."";// column binding
mysql_data_seek($WADAtyres, 0);
$ATC_itemQuantity = floatval($ATC_itemQuantity);
if (is_numeric($ATC_itemQuantity) && $ATC_itemQuantity != 0) {
$eCart1->AddToCart($ATC_AddIfIn, $ATC_RedirectIfIn, $ATC_itemID, $ATC_itemName, $ATC_itemDescription, $ATC_itemWeight, $ATC_itemQuantity, $ATC_itemPrice, $ATC_itemMake);
if ($ATC_RedirectAfter != "" && $eCart1->redirStr == "") {
$eCart1->redirStr = $ATC_RedirectAfter;
if (isset($_SERVER['QUERY_STRING']) && $_SERVER['QUERY_STRING'] != "") {
$_SESSION['WAEC_ContinueRedirect'] = $_SERVER['PHP_SELF']."?".$_SERVER['QUERY_STRING'];
else {
$_SESSION['WAEC_ContinueRedirect'] = $_SERVER['PHP_SELF'];
// WA eCart Redirect
if ($eCart1->redirStr != "") {
header("Location: ".$eCart1->redirStr);
And the button code;
<div class="WADAResultCommerceButton"><form name="eCart1_1_ATC_<?php echo $row_WADAtyres["tyresID"]; ?>" method="POST" action="<?php echo $_SERVER["PHP_SELF"]; ?><?php echo (isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] != "")?"?".$_SERVER["QUERY_STRING"]:""; ?>">
<input type="hidden" name="eCart1_1_ID_Add" value="<?php echo $row_WADAtyres["tyresID"]; ?>" >
<input type="text" name="eCart1_1_Quantity_Add" value="1" size="4" >
<input type="image" src="WA_eCart/Images/Nautica/Btn2_EN_addtocart.gif" border="0" value="Add to Cart" name="eCart1_1_ATC" alt="Add to cart">
</form></div>
there is probably a php error preventing the redirect from occurring. add the following at line 1 to turn on error reporting:
error_reporting
(E_ALL);
