Dreamweaver SQL returning extra results
Thread begun 1/03/2010 4:17 am by m_jelly386415 | Last modified 1/04/2010 12:26 pm by Jason Byrnes | 1644 views | 1 replies |
m_jelly386415
I'm having a problem with my database search query. It comes from a form asking either title, author or isbn - requesting a title returns perfection, requesting an author or isbn returns the correct result, plus 2 seemingly random results - but the same 2 odd results every time for every query.
Dim SearchQuery__MMColParam
SearchQuery__MMColParam = "1"
If (Request.Form("title") <> "") Then
SearchQuery__MMColParam = Request.Form("title")
End If
Dim SearchQuery__MMColParam2
SearchQuery__MMColParam2 = "1"
If (Request.Form("author") <> "") Then
SearchQuery__MMColParam2 = Request.Form("author")
End If
Dim SearchQuery__MMColParam3
SearchQuery__MMColParam3 = "0"
If (Request.Form("isbn") <> "") Then
SearchQuery__MMColParam3 = Request.Form("isbn")
End If
Dim SearchQuery
Dim SearchQuery_cmd
Dim SearchQuery_numRows
Set SearchQuery_cmd = Server.CreateObject ("ADODB.Command")
SearchQuery_cmd.ActiveConnection = MM_conn_STRING
SearchQuery_cmd.CommandText = "SELECT * FROM Stock WHERE title LIKE ? OR author_last LIKE ? OR isbn=?"
SearchQuery_cmd.Prepared = true
SearchQuery_cmd.Parameters.Append SearchQuery_cmd.CreateParameter("param1", 200, 1, 255, "%" + SearchQuery__MMColParam + "%") ' adVarChar
SearchQuery_cmd.Parameters.Append SearchQuery_cmd.CreateParameter("param2", 200, 1, 255, "%" + SearchQuery__MMColParam2 + "%") ' adVarChar
SearchQuery_cmd.Parameters.Append SearchQuery_cmd.CreateParameter("param3", 5, 1, -1, SearchQuery__MMColParam3) ' adDouble
Set SearchQuery = SearchQuery_cmd.Execute
SearchQuery_numRows = 0
you have the default values for the recordset parameters set to 1 and 0, try changing those to -1 for all of them.
