Creating a search form using Data Assist
Thread begun 1/02/2010 6:24 am by Paul | Last modified 1/12/2010 1:52 pm by Eric Mittman | 3811 views | 7 replies |
PaulBeta Tester
I'm using the DataAssist Search Wizard to create a search feature in my index.php page.
I have created the server behaviour and recordset for my search source used during the wizard to create my search form etc, however I was a little confused by the absence of the steps to create and link to the the results page - or have i missed something here
Would be grateful for any guidance around these steps and functionality.
Thank you, Paul
If you are using the wizard to create the search and results pages then you do not need to do anything further to get the search page to go to the results page, this should be automatic for you.
If you crafting one or both of the pages outside of the wizard you would get the search page to go to the results page by making the results page the action of the search form.
PaulBeta Tester
Eric,
I am using the DA Search Wizard. There are only 3 steps. There is no mention of the search results page in any of those steps.
Attached is screenshot of final page after 3 step.
Sorry about that, I should have been more clear. DataAssist has two wizards, there is the standard DataAssist wizard as well as the DataAssist Search wizard. I was referring to making use of the regular DataAssist wizard, this is the one that will create the search and results pages for you. Once the pages are crafted you can edit the DataAssist Search server behavior that is on the search page to get you search working just how you would like it.
If you do not use the regular DataAssist wizard to generate the pages you can create your own search page with a form on it and just set the action of the form to your results page. This is how the search links to the results.
webserv315208
Adapting Search to Customized Page
I would appreciate your assistance in figuring out why my page resulting in errors when I try to adapt an all ready customized list page (not using DA) with DataAssist's Search feature.
I did the following steps:
1. Created a form with a 'Search' textbox and a button called 'go'.
2. Accessed DataAssist Search
a. Trigger: button 'go' pressed
b. Recordset 'getEmployee', 'MySQL'
c. Default WHERE clause: "WHERE 0=0"
d. Server Behavior Configuration (I only created one for testing): Key, firstname, T=<?php echo $row_getEmployee['firstname']; ?>
3. RESULT when page first loads:
a. You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'WHERE 0=0' at line 1
How can I modify your DA code to where I don't need the WHERE clause (or do I?) if I have my own query displaying the results as I want them?
Also, I all ready have SESSIONS coded, how can I adapt DA's to where I don't need it?
4. How can I use your product with my web page? I've attached my web page code for your review, which includes the DA code as well.
Thank you in advance!
I think the error you are getting has to do with the where clause having the word where in it. You should try updating the where clause by removing the work where in it so it looks like this:
" 0=0"
The default where clause is a filter that will be applied to the recordset when there is no search value submitted. So if you leave this at the 0=0 you should get back all the records from your recordset without any filtering.
In regards to the session variables I'm not sure that I understand what you are asking. DataAssist Search will make use of session variables to hold the previous results if you were to visit the page again without searching.
As far as the code you have it seems fine to me other than the update that you should make to the default where clause. Please give this a try and let us know if you have any other problems.
webserv315208
I have made your recommended change and attempted to use the Search textbox by typing a firstname. I have receive the following errors:
Notice: Undefined variable: row_getEmployee in C:\...\list.php on line 92
Notice: Undefined variable: row_getEmployee in C:\...\list.php on line 93
Notice: Undefined variable: row_getEmployee in C:\...\list.php on line 94
Lines 92-94:
$WADbSearch1->keywordComparison($KeyArr1,"".$row_getEmployee['company'] ."","AND","=",",%20","%20","%22","%22",0);
$WADbSearch1->keywordComparison($KeyArr2,"".$row_getEmployee['firstname'] ."","AND","=",",%20","%20","%22","%22",0);
$WADbSearch1->keywordComparison($KeyArr3,"".$row_getEmployee['position'] ."","AND","=",",%20","%20","%22","%22",0);
I await your reply.
Seeing these errors and looking at the code it seems that you have the search configured incorrectly. In your comparisons you are making reference to the recordset values that come from the same recordset you are applying the search on. This will not work this way since the end result of the DataAssist Search server behavior is to produce a filtered recordset, using values from this filtered recordset in your search does not make sense.
The values you are comparing to are almost always posted values from a form. You should replace these recordset references in the comparison with their posted values from the search form. This way whatever is entered into the search form is what will be used to filter the recordset.
To do this on your results page you will first need to go to Bindings > Form Data, then select your search page. After you do this edit the DataAssist search server behavior and when selecting the values for the comparison use the lightning bolt to choose the form elements from your search form where the search terms are entered.
