activation needed everytime
Thread begun 1/02/2010 1:55 am by brunodarwin371999 | Last modified 1/06/2010 9:45 am by Office Guy-172461 | 4153 views | 7 replies |
brunodarwin371999
Hello,
Everyday I use Search for Boss, I must re-enter the code to activate.
Note : this is not the case for all the other WA plug-ins.
Is it normal ?
If not, what can I do to avoid this ?
Jimmy Wu
In our database, it shows that you have activated this product only once on the 18th of November. Have you ever gotten the too many activations error message or have you been able to activate every time?
brunodarwin371999
I must re-enter my serial number every time.
And after everything is ok. I didn't experienced any error message.
In fact if I close Dreamweaver CS3 and open it 2 seconds after, I must re-type the S/N if I use again Search for Boss. But never for the other Webassist Plug-ins (And I get Quite all of them)...
Jimmy Wu
I'm going to go ahead and clear that activation and see if that will fix the issue. After activating it again next time, give it another try and see if you are asked to activate again.
brunodarwin371999
I am glad to tell you the problem is cleared.
I don't know if there is a relationship but it started just after I remove the PalettePicker extension.
This morning I had some Javascript errors when I opened DWCS3.
I cleared all my HD and re-installed all. But at this point I still had the same problem with SearchForBoss.
I Unisntalled Search for Boos and re_installed it. > Now, everything is perfect.
Happy New year to all WebAssist Team & members !
Office Guy-172461
Don't forget to clear the cache after installing new extensions. Only takes a minute and can save a lot of grief.
See step 1:
Solving problems with Dreamweaver
146/
brunodarwin371999
Thank you for this
Office Guy-172461
You are quite welcome.
