Problem with DataAssist
Thread begun 1/01/2010 8:21 pm by donegan | Last modified 1/06/2010 10:41 am by Jason Byrnes | 2756 views | 6 replies |
donegan
Hi Everyone,
I am in the process of rewriting my web site in Dreamweaver.
I used SiteAssist Pro to create the new site, now I am in the process of
using Dreamweaver to the Admin Pages so that I can start adding data
to my Database.
As I worked though the Tutorial (to refresh my mind) everything went well up to Page 19 of the Tutorial.
Once I clicked the "Finish" button the Wizard created the Result and Search Pages, as it gets to the
Details Page I get a message from windows that Dreamweaver has encountered a problem and it
needs to close. (See the image attached)
Now the strange thing about this is it only happens if I am creating the Pages for the "Items" table in the
Blue Sky Music Database (using PHP, and the Blue Aky Music Database). When I create the Orders or
Visitors Table I do not get this error message and the Wizard creates the pages.
Again I am just working though the "DataAssist - Getting Started Guide" Tutorial.
I have set up PHP and MySQL and tested them to make sure they work. I uninstalled DataAssist and then
reinstalled after I restarted my computer. I have make sure the Site is attached to the proper Database.
I am running Windows XP Pro, SP3 and have checked for updated for Dreamweaver CS3.
Has anyone encountered this problem?
I would appreciate any help in this matter.
donegan
Problem Solved now new problem
Ok, I figured out what the proble was with Dreamweaver and fixed it by deleting the .dat file.
Now my new problem is I keep getting the following error when I preview and click on the seach button in the "Search Page" as outlined in the tutorial on Page 24.
Fatal error: Class 'FilterDef' not found in C:\wamp\www\SiteAssist\items_Results.php on line 10
Thanks for any help you can provided.
Sounds like the DataAssist Search include file reference is in the wrong place.
look for a line of code similar to:
//WA Database Search Include
require_once("WADbSearch/HelperPHP.php");
and move it to line 1 on your page.
donegan
Thank You
No that was not the problem.
The problem was on Page 13 of the Getting Started Guide it Step 9 has you select "ItemCatName" this item is not in the table.
The itemgategory table that you should be using in that step has only two columns, ItemCatID and ItemCatName.
I am including a screen shot that shows the structure for the itemcategory table.
donegan
Table Field
Yes, I created a print out of the tables and can see this field but for some reason using the
Getting Started Guide Instructions I get an error in Dreamweaver.
Please be more specific. What is the error? When does it occur?
