problema de codigo HTML editor
Thread begun 12/31/2009 6:07 am by test_res397386 | Last modified 1/04/2010 5:19 pm by Eric Mittman | 4603 views | 3 replies |
test_res397386
hola buenas esto tengo la ultima versión HTML editor resulta que cuando coloco una imagen desde el editor la coloca correctamente pero cuando miro el código fuente de la pagina veo que pone etiquetas como table o img
Código original
<table border="0" cellspacing="2" cellpadding="4" width="400" align="left" height="115"><caption>piezas</caption><tbody><tr><td style="text-align: center"><img alt="wp_img_icon_talleres_axa_calidad.png" width="50" height="50" src="../images/wp_img_icon_talleres_axa_calidad.png" /></td><td style="text-align: center"><img alt="wp_img_icon_talleres_axa_calidad.png" width="50" height="50" src="../images/wp_img_icon_talleres_axa_calidad.png" /></td></tr><tr><td></td><td></td></tr><tr><td></td><td></td></tr></tbody></table>
esto debería ponerlo asín
width="400px"
height="115px"
width="50px"
height="50px"
como puedo corregir este error del editor el porque no saca las medidas px,em,ems,puntos, etc.
My apologies for my limited language abilities but I'm not able to understand your post. Perhaps someone else in the community would be able to respond to this. If it is possible please post back with the question in English and we will do what we can to help you out.
gruant2000381341
translation
I found an online translater...copied this in and this is what I got back.
hi this is my last good version HTML editor is that when I put an image from the editor puts it correctly but when I look at the source of the page I see that labels as table or img
Original Code
<html><table border="0" cellspacing="2" cellpadding="4" width="400" align="left" height="115"><caption> pieces </caption><tbody><tr><td style="text-align: center"><img alt="wp_img_icon_talleres_axa_calidad.png" width="50" height="50" src="../images/wp_img_icon_talleres_axa_calidad.png" /></td> center "> <img alt="wp_img_icon_talleres_axa_calidad.png" width="50" height="50" src="../images/wp_img_icon_talleres_axa_calidad.png" /></td></tr><tr><td></td><td></td></tr><tr><td></td><td></td></tr></tbody></table>
this should put Asin
width="400px"
height="115px"
width="50px"
height="50px"
how can I correct this error because the publisher does not take measures px, em, ems, points, etc..
((translater address if you ever need it again.. spanish_to_english.html))
What is the exact output that you are adding into the editor? Also, are you adding it into the regular view or are you adding it to the code view? I will check into this further for you based on the info you post back.
