U.E. SMTP requires authentication
Thread begun 12/30/2009 1:56 pm by sandy170299 | Last modified 12/31/2009 1:54 pm by Jimmy Wu | 4562 views | 7 replies |
sandy170299
I am setting up a PHP system that will run on my localhost only. However, I'm having tons of trouble trying to get U.E. to work. On the first screen, it's asking me for my SMTP server, and my port, which is fine, except that my host requires authentication in order to send emails, and there is no option for me to enter my user name and password. How can I achieve this? Thanks!
Jimmy Wu
Here is another thread that the user has the same issue and was able to resolve it:
showthread.php?t=3923&highlight=authentication
sandy170299
I am very, very new to PHP. Is there something I need to do to get PEAR set up?
Jimmy Wu
Yes, you will have to set up PEAR on your server. It should be included with PHP, but you will have to set it up. Here is a tutorial on setting it up:
how-to-install-apache-php-mysql-phpmyadmin-windows-xp/
sandy170299
Is this tutorial valid for Vista, too? It only mentions XP...
Jimmy Wu
Here is a tutorial on setting up PHP with PEAR:
index.php?title=Setting_up_apache_and_php_in_vista
Did you use the wizard to set up your PHP?
sandy170299
I used XAMPP to install the Apache server, PHP and PHPMYADMIN.
Jimmy Wu
Looks like this is the way you would install pear on an xampp setup:
how-to-install-pear-modules-using-xampp/
