Universal email formatting body output
Thread begun 12/30/2009 1:15 pm by admin140217 | Last modified 1/06/2010 1:38 pm by Jimmy Wu | 5536 views | 8 replies |
admin140217
Hello,
Everything is working fine with Universal Email but I would like to have the output structured to separate information instead of a single line...
Example:
Currently is name email phone..
would like:
name
email
phone
Basically I want to break the line at the end of that fields output.
I have tried <br>, \n, and \r in the body's dynamic string but it's not working.
Suggestions,
Bob
Jimmy Wu
Have you tried using <br /> which is the correct line break for XHTML?
admin140217
Originally Said By: Jimmy Wu
yes, that was tried and I'm still getting a single string output
Jimmy Wu
What's the email code look like?
admin140217
email code
Jimmy,
The form is typical:
<form action="contact.php" method="post">
The email code from Universal email's output in the WAUE_contact_1.php is below:
//Start Mail Body
$MailBody = $MailBody . "";
$MailBody = $MailBody . ((isset($_POST["company"]))?$_POST["company"]:"");
$MailBody = $MailBody . "\r\n";
$MailBody = $MailBody . ((isset($_POST["name"]))?$_POST["name"]:"");
$MailBody = $MailBody . ((isset($_POST["phone"]))?$_POST["phone"]:"");
$MailBody = $MailBody . ((isset($_POST["email"]))?$_POST["email"]:"");
$MailBody = $MailBody . ((isset($_POST["comments"]))?$_POST["comments"]:"");
//End Mail Body
Happy New Year!
Bob
Jimmy Wu
Do you have an Email_Templates directory in your WA_Universal_Email directory? Universal email will use the templates in that directory to create the emails. These templates would be coded in html.
For example the $MailBody creation should look like this for the email template contactus.php:
//Start Mail Body
ob_start();
require_once(dirname(__FILE__) . ("/Email_Templates/contactus.php"));
$contents = ob_get_clean();
$MailBody = $MailBody . ($contents);
//End Mail Body
What were the steps you took to set up your Universal Email?
admin140217
Email templates
Jimmy,
I'm not using a template, I didn't feel that was necessary for a simple form although I will keep this in mind for future forms.
The steps I took were to create the form then apply the Universal email behavior to it going through the tabs in its options panel.
There should be a simple method to create a line break for the field information in the behavior extension, shouldn't there? I would have thought that when formatting the body (in the body tab) HTML, or palin text I could indert a break manually but that doesn't seem to want to work
Bob
admin140217
Problem solves
Univeral email seems to want to be in the root directory and not a sub folder, also did hard retuns in the body tab.
Jimmy Wu
Glad to hear you were able to get the email sent correctly. If you run into any additional issues, feel free to open a new thread.
