WI Sales Tax setup
Thread begun 12/30/2009 6:01 am by brihod61 | Last modified 3/22/2010 8:31 am by neileisen207079 | 3814 views | 6 replies |
brihod61
WI Sales Tax setup
Looking for some help in setting up Sales Tax for state of WI. We have 4 different sales taxes in the state and you must charge sales tax based on purchaser's address. I would like to have the correct sales tax be applied based on the purchaser's zip.
Any incite greatly appreciated
thanks
Do you know what tax rates apply to the various zip codes? This will be necessary in order to charge the correct tax rate.
The idea is that you would have a set of tax rules. The first condition in the trigger for the tax rule would be that the state selected was WI. The next conditions will be if the entered zip matches a particular set of zip codes. If so then the tax rate for that set of zip codes would be used.
You would then have a different tax rule constructed like this for each potential tax rate.
If you have the info in a table in your db that holds the zip and corresponding tax rate you could do a recordset lookup of the tax rate based on the user submission and store the tax rate in a session variable. You could then have a rule that is triggered on the presence of this session variable, then use the session variable again in the calculation for the rate.
The first path is the static one, the second is the dynamic way to go. Let us know what direction you would like to take and include any questions that you have about the specifics.
brihod61
Hi Eric,
I do have my zips an a table, so that part is done.
Table is set up as such
id | zipCode | zipZone | zipRate
zipZone being 1-4 for zone and rate column being the sales tax %
That is great that you have a table with the info. So the idea is that you will create a recordset on the confirm page. This recordset will be filtered on the posted zip value if the selected state is WI.
To make sure this recordset is only created when the user selects WI you will need to add a custom if statement around the rs, it might look like this depending on your checkout form name for that field:
if(isset($_POST['state_province']) && $_POST['state_province'] == "WI"){
// the recordset goes here
Once the recordset is crafted you will add in a set session value server behavior. You give your session variable a name and for the value use the bindings to store the tax rate in this new variable.
Once you have done that you can craft the tax rule for the zip code. Create a new tax rule and for the trigger you will have two conditions. The first condition will be that the session variable exists and the second condition will be that it is not "" or blank.
Then for the calculation portion you will use the subtotal for the entire cart and multiply it by your session variable. You will need to enter your session variable like you would in code:
$_SESSION['tax_rate']
Please post back with any questions that you may have about any part of this.
neileisen207079
question
My client also wants the sales tax to be correct for every zip code in NY State, which is what they say they are required to do. I have also downloaded an updated table with sales tax rates in NY...
My question is could I use the existing tax rule, which already has 2 conditions: The first is that the shipping State = NY, and the second that an additional field in my database which tells me if they have a resale certificate on file = N (for no). Couldn't I just use that same rule, only change the calculation to that session variable you are talking about?
Why does the recordset on the page have to be conditional on the proper State being selected if tax is only applied based on that condition already?
Am I making this too confusing? And why isnt everyone worried about this problem? Are most States the same tax for the whole State?
I would add a recordset to the top of the confirm page that filters the a database and returns the correct tax rate based on the entered zip.
Then store that value in the session and use the session variable as the tax rate in your rule.
neileisen207079
Thanks Ray,
I did that and it worked great. I wouldnt have known how to enter it in the formula for the sales tax rate, so I appreciate this post. Again, I would think everyone would be interested in how to do this, unless everyone is smarter than me and already figured it out on their own. ;)
