Grid+Lightbox Displaying Problem Using IE8
Thread begun 12/29/2009 5:31 pm by paputxi | Last modified 12/31/2009 9:47 am by paputxi | 5247 views | 6 replies |
paputxi
I have successfully integrated PG into my website. I have one gallery that has 15 photos in it and I am displaying it using Grid+Lightbox.
In Firefox, Safari and Chrome browsers, the images display correctly, i.e, with 5 images per row. So, no problem here.
However, in IE8 it displays only 4 images per row. The background layer is grayed such that it indicates that a fifth image should appear (just like in the other browsers), but it doesn't. Rather, the fifth image goes to the next row.
Has anyone else encountered this problem with IE8? If so, how did you resolve it? Thanks in advance.
neilo
Make sure that the containing div that holds your gallery include has been assigned a width, and that it is wide enough to contain the five columns. You may need to do a bit of trial and error to set the minimum width without forcing the grid to displace the fifth column.
If you have problems, post a link to your gallery page so we can have a look at it and suggest a remedy.
paputxi
The div appears to be okay. You can see what is happening at students0910.php. Again, the problem only appears in IE8. You will see there is space for the fifth image, but it doesn't appear in that space as it does with the other browsers.
It appears that it is the width that is assigned in the .pg-gl style in the common.css file. The file is the one located here:
common.css
In this file near line 11 is this style:
/* wrapper
.pg-gl {
width: 720px;
font-family: Arial, Helvetica, sans-serif;
background-color: #1e1e1e;
padding: 8px 0 8px 8px;
If you adjust the width in here to 725px it looks like it will allow the images to fit.
paputxi
Yes, that solved the problem! My issue has been resolved.
Thanks, Eric!
neilo
The issue also resolves in IE8 without adjusting the css if you specify a DOCTYPE in the HEAD area. i.e:
You should really add the proper heading to your pages as IE gets a bit temperamental without the DOCTYPE being specified.
paputxi
Thanks, neilo! That is the best solution. I've now corrected my templates to include that information.
