No entry in database
Thread begun 12/29/2009 1:43 pm by i.edwards384429 | Last modified 1/05/2010 3:40 pm by Jimmy Wu | 2449 views | 4 replies |
i.edwards384429
Hi
using the user solution and lots of help I've sort of got it all working.
Just worked through the adding a digital file pro to the insert pages and to my surprise it worked but ( ok there's always a but) I discovered that although the files are being uploaded to the correct directories the database is not being updated.
Would appreciate a hint as to how to start trouble shooting
thanks
Ian
Jimmy Wu
Digital file pro upload does not insert into the database automatically. You will have to insert the information into the database after the upload. You can get the relevant information from the upload in the bindings panel.
i.edwards384429
update
Hi
IN the Server behaviours panel I do have Insert record (users)
with the code in the head as below.
I thought this was the code that added the entries to the database?
Is this not so?
thanks
Ian
// WA Application Builder Insert
if ($_SERVER["REQUEST_METHOD"] == "POST") // Trigger
$WA_connection = $localhost;
$WA_table = "users";
$WA_sessionName = "users_UserID";
$WA_redirectURL = "";
$WA_keepQueryString = false;
$WA_indexField = "UserID";
$WA_fieldNamesStr = "UserImage1|UserImage2|UserImage3|UserImage4|UserImage5";
$WA_fieldValuesStr = "".$WA_DFP_UploadStatus["WA_UploadResult1"]["serverFileName"] ."" . "|" . "".$WA_DFP_UploadStatus["WA_UploadResult2"]["serverFileName"] ."" . "|" . "".$WA_DFP_UploadStatus["WA_UploadResult3"]["serverFileName"] ."" . "|" . "".$WA_DFP_UploadStatus["WA_UploadResult4"]["serverFileName"] ."" . "|" . "".$WA_DFP_UploadStatus["WA_UploadResult5"]["serverFileName"] ."";
$WA_columnTypesStr = "',none,''|',none,''|',none,''|',none,''|',none,''";
$WA_connectionDB = $database_localhost;
$insertParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WA_Sql = "INSERT INTO `" . $WA_table . "` (" . $insertParamsObj->WA_tableValues . ") VALUES (" . $insertParamsObj->WA_dbValues . ")";
$_SESSION[$WA_sessionName] = mysql_insert_id();
if ($WA_redirectURL != "") {
i.edwards384429
update
Hi
been through the tutorial again and have been working with just the insert page located at
users_Insert.php
(I haven't restricted any access yet - I add the link for code view purposes)
If I go to
users_LogIn.php
and log in I've set this up to go to the users_Insert.php page.
( used data assist wizard on the users table)
On the users_Insert.php page I've added five upload fields which work and upload images perfectly.
I then followed the instructions to add the insert record behavior using the dataAssist isert record behaviour.
That added the code below:
$WA_fieldNamesStr = "UserImage1";
$WA_fieldValuesStr = "".$WA_DFP_UploadStatus["WA_UploadResult1"]["serverFileName"] ."";
$WA_columnTypesStr = "',none,''";
When I upload however no entry is made in the database
Any ideas?
thanks
Ian
Jimmy Wu
Have you tried testing the database insert behavior on a regular form? It could be that the insert behavior is not being added correctly to insert into your database.
So create a blank page and try creating a form and applying the insert server behavior to insert the form elements into a database table and see if that works.
Is the form action set to POST or is it set to another value?
