image folder location
Thread begun 12/29/2009 1:20 pm by gruant2000381341 | Last modified 12/30/2009 10:37 am by Dani Chankhour | 2113 views | 3 replies |
gruant2000381341
Just downloaded the cms101 revision update. I was wanting to add a pdf folder, on the prior version I added this in the Globals with the images and swf but they are not there now. How do I locate those?
Dani Chankhour
Since the PowerCMS dot release was upgraded to the new HTMLEditor and also was upgraded to use the KFM editor(Advance Upload) all the files are now stored under files/cms_files folder which is created the first time you try to upload any file to your server.
If you want to change where you want certain files to be changed, then under the HTMLEditor/editor/filemanager/connectors/php/ folder, open the config.php file.
At the bottom of the page, you will need to change:
$Config['FileTypesPath']['File'] and the $Config['FileTypesAbsolutePath']['File'] settings where your new location.
gruant2000381341
thanks, do you know if it creates a new folder for each type of media ( flash, images, etc.) or is it just 1 "master" folder?
Dani Chankhour
It will create a master folder and places everything in that folder.
