address marker :: can it be set up to not display on the page by default?
Thread begun 12/29/2009 12:34 pm by sandy170299 | Last modified 2/09/2010 12:24 pm by Jimmy Wu | 6235 views | 14 replies |
sandy170299
Can I change a setting to NOT have the address market show when the page loads? Also, instead of clicking on a marker to display the data, can it be set up to show the marker when you mouse-over a location?
Jimmy Wu
For each of the markers in wagmp_map_<mapnum>.php, you will want to find this code:
GEvent.addListener(marker_0, 'click', function() {
marker_0.openInfoWindowHtml(address_0.infowindowtext);
and change the click to mouseover, so it looks like this:
GEvent.addListener(marker_0, 'mouseover', function() {
After that, you will want to add another event listener to close the window on mouseout (if that is the functionality you want).
GEvent.addListener(marker_0, 'mouseout', function() {
marker_0.closeInfoWindow();
To prevent the info window from popping up on default, you will have to find the code similar to this for each marker and remove it:
if('address_0' == 'address_0')
sandy170299
Jimmy, I don't have this code. It's dynamic, so the closest I have is:
if (point && !isNaN(latitude)) {
wagmp_map_1_obj.addressFailed = false;
var marker_0_<?php echo $getListing_id; ?> = new GMarker(point, icon_0);
GEvent.addListener(marker_0_<?php echo $getListing_id; ?>, 'mouseover', function() {
marker_0_<?php echo $getListing_id; ?>.openInfoWindowHtml(address_0_<?php echo $getListing_id; ?>.infowindowtext);
Is this the right code to change?
sandy170299
Jimmy, I'm attaching my code.
Jimmy Wu
You would be removing this code to get the window from not popping up initially:
if('address_0_<?php echo $getListing_id; ?>' == 'address_0_0')
And this is the code that you would use for changing the mouseover:
GEvent.addListener(marker_0_<?php echo $getListing_id; ?>, 'click', function() {
Change the click to mouseover:
To add the mouseout:
GEvent.addListener(marker_0_<?php echo $getListing_id; ?>, 'mouseout', function() {
marker_0_<?php echo $getListing_id; ?>.closeInfoWindow();
sandy170299
Works perfectly, Jimmy. Thank you! Can this be a feature that is added to the next version of this extension? That would rock!
Jimmy Wu
I will put in a feature request for this and it may be added into a future release.
sandy170299
I'm also requesting the ability to add a default zoom level through the wizard because every time I go into the wizard to change something, it deletes the info I entered about the zoom level.
Thanks!
Jimmy Wu
If you could make a thread to request that in the wishlist forum, it will be looked over.
If you run into any additional issue, feel free to open a new thread.
sandy170299
Jimmy, this stopped working again after I edited a map. Here is the page:
canadian-hunting.php
