Error message when using eCart
Thread begun 12/29/2009 10:57 am by michel336265 | Last modified 1/27/2011 10:15 am by Ray Borduin | 4008 views | 3 replies |
michel336265
I want to use the eCart extension. However when I want to add "add to basket" the following error occured :
onMouseUp in WA eCart AddToCart.htm an JavaScript error :
On line 147 off file C:\Program Files\Adobe Dreamweaver CS3\Configuration\Commands\WAeCart AddtoCart.js:
The object is currently not in a document
Can someone please tell me how to fix this problem?
With regards
Michel
Holland
p.s I have translated the error from Dutch into English
Jimmy Wu
What values are you specifying when setting up the Add To Cart server behavior? Could you take screen shots of the wizard and post them here?
Also, which version of eCart are you running?
jcholt7640
I have the same problem
Running Ecart 4.5.2
Please Help. I have gone so far as to de-install/re-install DW5 and still have the issue.
I have opened a support ticket so that we can work with you directly to try to resolve this issue.
