Search bar on more than one page
Thread begun 12/29/2009 6:34 am by muddysmurf | Last modified 12/31/2009 1:54 pm by Eric Mittman | 3638 views | 6 replies |
muddysmurf
I have a search bar that is going to be in my header. Let's say it's going to be on about 7 pages. I see this all the time, and I could do it manually but I don't feel like doing all of the code work. I know this has to be possible with dataassist search wizard.
Last night, I was on my index.php page (where my search form name/id is searchme). I did the dataassist search wizard, but it wouldn't let me choose that form. I then had to choose a page that I was going to use..so I chose search.php.
Finally, once finished, I ended up with another form on search.php, but a lot of code on the index.php. It apparently doesn't work lol
What is the easiest way to put this search on the different pages that I need...and use one results page.
Thanks!
Having a search occur from different pages on the site is fairly straight forward. The results page is just looking for posted values. So all you need to do to get the search on multiple page is add in the currently working search form that you have to the pages where you would like the search to be performed from.
So long as the form is posting to the results page you should get the same results regardless of where you initiate the search.
muddysmurf
I matched up everything to the form.. but when I search for something, it shows all of the items in the database.
Not sure why this is occurring considering I compared another site that I did a while back to this one. They are done a little differently with how the search fields are laid out, but that shouldn't matter.
I have a feeling it may be the way I coded the search bar...
I'll post my code up later tonight, since I am at work.
muddysmurf
The form is:
<div id="searchwrapper"><form action="search.php" name="searchme" id="searchme">
<input type="text" class="searchbox" name="s" value="" />
<input type="image" src="images/blankSearch.png" class="searchbox_submit" name="" value="Submit" />
<table cellpadding="2" cellspacing="0" border="0">
<tr>
<td align="center"><input type="hidden" name="WADbSearch1" value="Submit" /></td>
</tr>
</table>
</form>
</div>
reason I'm thinking it might be the form is the way the last two inputs are.. I have an image for my "submit" button..and then when I added the search, it made it hidden. I could be totally wrong though.
I may have to rip every piece of code out and try again...
The form here seems ok to me, but depending on how your search is setup you may not be triggering it properly. If you can please post back with your results page in a zip archive so that we can take a look at it.
I will check on some things to see if the triggers match up and try to determine why you are not getting the search to work.
Also, do you have a search form anywhere on the site that is working? If so please post back with this as well in a zip archive.
muddysmurf
Here is the zip file.
It looks like you have the trigger for the search specified as:
if ((isset($_POST["WADbSearch1"])) && ($_POST["WADbSearch1"] != "")) {
This is just looking for the posted WADBSearch1 variable. It looks like your form has this as a hidden form element in it. Looking further into the search criteria that is set on this page I can see that you are looking to do a keyword type of comparison with includes using the $_POST["advancedText"] value. I do not see this value in your search form that you posted. It looks like the only field in the form is named 's'.
I think that you could get the search page working for this form if you altered line 20 of the search page to be like this:
$WADbSearch1->keywordComparison($KeyArr1,"s","AND","Includes",",%20","%20","%22","%22",0);
This could potentially break other search forms on your site though if they rely on the other value to be submitted. The best thing to do would be to look at a search form you have that is currently working and ensure that the other search forms have the same inputs in them.
