Email sends, but form data not in email
Thread begun 12/28/2009 2:31 pm by caroline379050 | Last modified 10/27/2010 2:47 pm by Dani Chankhour | 7196 views | 16 replies |
caroline379050
I created a test page to try this and The info I created in my form isn't sent in the email. I did not do any validation, but is this necessary?
I used Form Builder with Universal Email AND did it with building my own form. Neither sent the filled in field info that was created in the form.
Like I mentioned in the Title. I receive the email okay, just no information from the form being filled out. I am using the POST method.
Caroline
Dani Chankhour
In order to send the form data in your email, you will need to add the form data to your email.
You could do that in Universal Email by clicking the Body tab and then clicking the DW Edit button and then you can use the Bindings Panel (Window -> Bindings) to drag the form elements to your page.
caroline379050
That helped some, but need to play with it more to figure out how to have the name show in the email, plus I need to send the submitter to a page stating they sent their question successfully. I found a tutorial that shows how to do this in code. Which I have been able to do, but I thought these 2 extensions would alleviate all the coding. and allow me to just design. Oh well. onward and upward.
thanks for your time.
Caroline
Dani Chankhour
To include the form data in your email, yo should not have to write any custom coding. Using Dreamweaver Bindings Panel should allow you to drag the form elements to your page after you click the DW Edit button under the Body Tab in Universal Email. You could also apply your designs to the same page, such as adding tables or divs to format the output.
dbarry4377469
same issue
I put the bindings in and still no data appears........
dbarry4377469
Here's the form link:
testcontact.php
and email content rec'd looks like this: no data
Contact me
Required *
Name *
Please enter your name
Email *
Invalid format.Please enter a full email address
Comments *
Please provide a comment
Dani Chankhour
in the WA_Universal_Email folder, please send me the file "WAUE_yourpage.php"
This will allow me to see if the binding is done correctly.
dbarry4377469
Code part 1
$MailAttachments = "";
$MailBCC = "";
$MailCC = "";
$MailTo = "";
$MailBodyFormat = "";
$MailBody = "";
$MailImportance = "";
$MailFrom = "DBWEB|WA|dbarry4@mac.com";
$MailSubject = "Contact Form";
$_SERVER["QUERY_STRING"] = "";
//Global Variables
$WA_MailObject = WAUE_Definition("mail.mac.com","25","dbarry4@mac.com","","","");
if ($RecipientEmail) {
$WA_MailObject = WAUE_AddRecipient($WA_MailObject,$RecipientEmail);
else {
//To Entries
//Attachment Entries
//BCC Entries
//CC Entries
//Body Format
$WA_MailObject = WAUE_BodyFormat($WA_MailObject,0);
//Set Importance
$WA_MailObject = WAUE_SetImportance($WA_MailObject,"3");
//Start Mail Body
$MailBody = $MailBody . "<html><head>\r\n";
$MailBody = $MailBody . "<script src=\"SpryAssets/SpryValidationTextField.js\" type=\"text/javascript\"></script>\r\n";
$MailBody = $MailBody . "<script src=\"SpryAssets/SpryValidationTextarea.js\" type=\"text/javascript\"></script>\r\n";
$MailBody = $MailBody . "<link href=\"SpryAssets/SpryValidationTextField.css\" rel=\"stylesheet\" type=\"text/css\" />\r\n";
$MailBody = $MailBody . "<link href=\"SpryAssets/SpryValidationTextarea.css\" rel=\"stylesheet\" type=\"text/css\" />\r\n";
$MailBody = $MailBody . "</head><body>\r\n";
$MailBody = $MailBody . "<form class=\"NewFromBlank_Default\" id=\"SimpleContact_NewFromBlank_Default\" name=\"SimpleContact_NewFromBlank_Default\" method=\"post\" action=\"testcontact.php\">\r\n";
$MailBody = $MailBody . " <!--\r\n";
$MailBody = $MailBody . "WebAssist CSS Form Builder - Form v1\r\n";
$MailBody = $MailBody . "CC: Contact\r\n";
$MailBody = $MailBody . "CP: Simple Contact\r\n";
$MailBody = $MailBody . "TC: <New From Blank>\r\n";
$MailBody = $MailBody . "TP: Default\r\n";
$MailBody = $MailBody . "-->\r\n";
$MailBody = $MailBody . " <ul class=\"NewFromBlank_Default\">\r\n";
$MailBody = $MailBody . " <li>\r\n";
$MailBody = $MailBody . " <fieldset class=\"NewFromBlank_Default\" id=\"Contact_me\">\r\n";
$MailBody = $MailBody . " <legend class=\"groupHeader\">Contact me</legend>\r\n";
$MailBody = $MailBody . " <ul class=\"formList\">\r\n";
$MailBody = $MailBody . " <li class=\"formItem\"> <span class=\"fieldsetDescription\"> Required * </span></li>\r\n";
$MailBody = $MailBody . " <li class=\"formItem\">\r\n";
$MailBody = $MailBody . " <div class=\"formGroup\">\r\n";
$MailBody = $MailBody . " <div class=\"lineGroup\">\r\n";
$MailBody = $MailBody . " <div class=\"fullColumnGroup\">\r\n";
$MailBody = $MailBody . " <label for=\"Contact_me_group_Name\" class=\"sublabel\" > Name<span class=\"requiredIndicator\">&nbsp;*</span></label>\r\n";
$MailBody = $MailBody . " ";
$MailBody = $MailBody . (ValidatedField("testcontact","Contact_me_group_Name"));
$MailBody = $MailBody . "\r\n";
$MailBody = $MailBody . " <div class=\"errorGroup\">\r\n";
$MailBody = $MailBody . " <div class=\"fieldPair\">\r\n";
$MailBody = $MailBody . " <div class=\"fieldGroup\"> <span id=\"Contact_me_group_Name_Spry\">\r\n";
$MailBody = $MailBody . " <input id=\"Contact_me_group_Name\" name=\"Contact_me_group_Name\" type=\"text\" value=\"";
$MailBody = $MailBody . ((isset($_GET["invalid"])?ValidatedField("testcontact","Contact_me_group_Name"):""));
$MailBody = $MailBody . "\" class=\"formTextfield_Large\" tabindex=\"1\" onblur=\"hideServerError('Contact_me_group_Name_ServerError');\"/>\r\n";
$MailBody = $MailBody . " <span class=\"textfieldRequiredMsg\">Please enter your name</span></span>\r\n";
if (ValidatedField('testcontact','testcontact')) {
if ((strpos((",".ValidatedField("testcontact","testcontact").","), "," . "1" . ",") !== false || "1" == "")) {
if (!(false)) {
$MailBody = $MailBody . " <span class=\"serverInvalidState\" id=\"Contact_me_group_Name_ServerError\">Please enter your name</span>\r\n";
//WAFV_Conditional testcontact.php testcontact(1:)
dbarry4377469
code part 2
$MailBody = $MailBody . " </div>\r\n";
$MailBody = $MailBody . " <label for=\"Contact_me_group_Email\" class=\"sublabel\" > Email<span class=\"requiredIndicator\">&nbsp;*</span></label>\r\n";
$MailBody = $MailBody . (ValidatedField("testcontact","Contact_me_group_Email"));
$MailBody = $MailBody . " <div class=\"fieldGroup\"> <span id=\"Contact_me_group_Email_Spry\">\r\n";
$MailBody = $MailBody . " <input id=\"Contact_me_group_Email\" name=\"Contact_me_group_Email\" type=\"text\" value=\"";
$MailBody = $MailBody . ((isset($_GET["invalid"])?ValidatedField("testcontact","Contact_me_group_Email"):""));
$MailBody = $MailBody . "\" class=\"formTextfield_Large\" tabindex=\"2\" onblur=\"hideServerError('Contact_me_group_Email_ServerError');\"/>\r\n";
$MailBody = $MailBody . " <span class=\"textfieldInvalidFormatMsg\">Invalid format.</span><span class=\"textfieldRequiredMsg\">Please enter a full email address</span></span>\r\n";
if ((strpos((",".ValidatedField("testcontact","testcontact").","), "," . "2" . ",") !== false || "2" == "")) {
if (!(false)) {
$MailBody = $MailBody . " <span class=\"serverInvalidState\" id=\"Contact_me_group_Email_ServerError\">Please enter a full email address</span>\r\n";
//WAFV_Conditional testcontact.php testcontact(2:)
$MailBody = $MailBody . " <label for=\"Contact_me_group_Comments\" class=\"sublabel\" > Comments<span class=\"requiredIndicator\">&nbsp;*</span></label>\r\n";
$MailBody = $MailBody . (ValidatedField("testcontact","Contact_me_group_Comments"));
$MailBody = $MailBody . " <div class=\"fieldGroup\"> <span id=\"Contact_me_group_Comments_Spry\">\r\n";
$MailBody = $MailBody . " <textarea name=\"Contact_me_group_Comments\" id=\"Contact_me_group_Comments\" class=\"formTextarea_Medium\" rows=\"1\" cols=\"1\" tabindex=\"3\" onblur=\"hideServerError('Contact_me_group_Comments_ServerError');\">";
$MailBody = $MailBody . ((isset($_GET["invalid"])?ValidatedField("testcontact","Contact_me_group_Comments"):""));
$MailBody = $MailBody . "</textarea>\r\n";
$MailBody = $MailBody . " <span class=\"textareaRequiredMsg\">Please provide a comment</span></span> </div>\r\n";
$MailBody = $MailBody . " </li>\r\n";
$MailBody = $MailBody . " <div class=\"columnGroup\">\r\n";
$MailBody = $MailBody . " <label for=\"Contact_me_group_Security_code\" class=\"sublabel\" >&nbsp;</label>\r\n";
$MailBody = $MailBody . " <div class=\"columnGroup\" style=\"clear:left;\">\r\n";
$MailBody = $MailBody . " <div class=\"fieldPair\"> </div>\r\n";
$MailBody = $MailBody . " <div class=\"wideColumnGroup\">\r\n";
$MailBody = $MailBody . " <div class=\"wideColumnGroup\" style=\"clear:left;\">\r\n";
$MailBody = $MailBody . " </ul>\r\n";
$MailBody = $MailBody . " </fieldset>\r\n";
$MailBody = $MailBody . "</form>\r\n";
$MailBody = $MailBody . "<script type=\"text/javascript\">\r\n";
$MailBody = $MailBody . "<!--\r\n";
$MailBody = $MailBody . "var Contact_me_group_Name_Spry = new Spry.Widget.ValidationTextField(\"Contact_me_group_Name_Spry\", \"none\",{validateOn:[\"blur\"]});\r\n";
$MailBody = $MailBody . "var Contact_me_group_Email_Spry = new Spry.Widget.ValidationTextField(\"Contact_me_group_Email_Spry\", \"email\",{validateOn:[\"blur\"]});\r\n";
$MailBody = $MailBody . "var Contact_me_group_Comments_Spry = new Spry.Widget.ValidationTextarea(\"Contact_me_group_Comments_Spry\",{validateOn:[\"blur\"]});\r\n";
$MailBody = $MailBody . "//-->\r\n";
$MailBody = $MailBody . "</script>\r\n";
$MailBody = $MailBody . "</body></html>";
//End Mail Body
$WA_MailObject = WAUE_SendMail($WA_MailObject,$MailAttachments,$MailBCC,$MailCC,$MailTo,$MailImportance,$MailFrom,$MailSubject,$MailBody);
$WA_MailObject = null;
Dani Chankhour
Thanks.
It looks like you did not do the bindings correctly. You only included the html, but no the value of the form elements.
When you click the DW Edit button, open the Bindings Panel by going to Window -> Bindings in Dreamweaver. And then expand the form entry (for example, it might said something like "SimpleContact_NewFormBlank_..."), and under it you will see the bindings, such as the name, email and comments. Then drag each one of those to emailbody box.
I have attached a sample of how your Universal Email page should look like.
