Can eCart Be Used to Receive Data Back From Linkpoint?
Thread begun 12/28/2009 2:08 pm by georgehayes205232 | Last modified 12/29/2009 10:41 am by Eric Mittman | 1254 views | 1 replies |
georgehayes205232
I would like to have LinkPoint send transaction details back to my database when the transaction is complete. I am using LinkPoint Gateway Connect, not the API. Can this be done using eCart? I can't find anything specific to this.
Thank you.
You should be able to make use of the remote checkout bindings for linkpoint to get back the info that they post for the transaction.
In order to set this up you will first need to login to your linkpoint account and enable the post back and specify the page. The specific steps you will need to take are listed in the eCart help documentation, here is the info from the help for your convenience:
  Retrieving transaction information from the payment gateway
LinkPoint performs a form POST containing the information pertinent to your transaction to an http:// location. You must enable the POST of this information and configure the passback location in your LinkPoint account in the following location for this information to be returned to your site:
1. Go to LinkPoint Central and login with your merchant account information.
2. In the top navigation, click the Customization link.
3. In the left navigation, click Settings.
4. Specify the http:// location that the transaction details should be posted to upon completion of the transaction for both the Confirmation and the Failure pages.
5. Select URL is a CGI script to enable the appropriate POST to get the information sent to the specified pages.
6. In addition, if AutoForwarding is selected, the destination pages for the POST are redirected to, and can display the outcome of the transaction on the return to your website.
The WA Local Checkout Response data bindings provides all of the variables passed back to the specified page through the Bindings panel. These bindings can be applied to the page for you to use and store the transaction information on your website.
The variables passed back to your site using this method are the same variables that can be passed to the website initially, as well as information specific to the processing of the transaction that are generated during processing.
Please refer to the LinkPoint (First Data) Connect help documentation referenced at the top of this page for a complete list of the variables available for retrieval from the LinkPoint gateway.
The help info for this can be found at Help > WebAssist > eCart > Using eCart, from there choose configuring checkout support > gateway specific configuration info > Remote Checkout > Linkpoint.
Once you have it configured you can get the bindings for this posted info by going to Bindings > eCart > Checkout > Checkout Form Response and choose linkpoint from the list. You can then use these bindings in your server behaviors.
