how do I change weight
Thread begun 12/28/2009 8:57 am by roxcastaneda251760 | Last modified 4/06/2010 11:23 am by mark292970 | 5052 views | 10 replies |
roxcastaneda251760Beta Tester
The weight is in lbs. I wanted to be in grams.
How do I make this change?
Dani Chankhour
You could make this change easily if you have eCart? Otherwise, i could show where you have to make that change in the code.
Yes, I have ecart. How do I make the change? Please be as detailed as possible because I don't know php. Thanks.
Dani Chankhour
In PowerStore, please open the index.php page. And then open the Server Behaviors Panel (Window -> Server Behaviors). Double click the eCart Object and under Weight select the symbol that you would like to use. click Ok.
Make sure to re-upload the WA_eCart folder.
I get an error message:
While executing timer in WA eCart Object.htm, the following error occurred:
At line 229 of file "C\Program Files\Adobe\Adobe Dreamweaver CS4\Configuration\Commands\WA eCart Object.js": document.generalWP.document.objPersistance.options[OBJECTDEF.Persistance] has no properties
Perhaps it would be faster if you teach me how to make the change in the PowerStore
Dani Chankhour
Sure,
In the WA_eCart folder, opend the WA_Store_Cart_PHP.php file and on line 298:
you can change "lb" to any of the supported weights: kg, oz, g, t, and tn.
Thanks. Happy New Year!
Dani Chankhour
Thanks.
I just want to mention that changing the weight in eCart, does not effect how the shipping is being calculated. If you are changing the weight for shipping, you will need to make the change in the Shipping Server Behavior as well.
mark292970
Weight Issue
I did exactly as decribed on how to update the weight from LBs to Ounces. Basicall I just doubled clicked the server behavior , however the weight was already ounces. I then uploaded my index and WA_ecart folder as instructed now my index page is displying the following
Parse error: syntax error, unexpected ')' in /home/markmusicman/natural-image.dreamhosters.com/WA_eCart/WA_Store_Cart_PHP.php on line 114
Please help?
mark
