Detail.php Missing
Thread begun 12/27/2009 1:05 pm by canonman208475 | Last modified 12/29/2009 4:14 pm by Eric Mittman | 3761 views | 6 replies |
canonman208475
Detail.php Missing
I am working with the "Blue Sky Music" tutorial and got to the point where I was to open detail.php and it isn't in the files. How can I download this file?
Have you downloaded the completed and support files? These files are available in the download area for eCart under the sections titled:
eCart GSG: Dynamic Completed Files
eCart GSG: Dynamic Support Files
If you are going the static route then you must use the corresponding static guide and you will not have the detials page in the site. Instead of having a dynamic details page you would have a static details page for each product.
canonman208475
I downloaded the completed and support files.
The page does not open correctly not as shown on page 38 of tutorial. No images. Plus when I try to connect recordset I get following error
Warning: require_once(file:///C|/Users/John/AppData/Local/Temp/Temp2_store_dynamic_sp_php.zip/store_dynamic_sp_php/Connections/connBSM.php) [function.require-once]: failed to open stream: Invalid argument in C:\wamp\www\dynamic\detail.php on line 1
Fatal error: require_once() [function.require]: Failed opening required 'file:///C|/Users/John/AppData/Local/Temp/Temp2_store_dynamic_sp_php.zip/store_dynamic_sp_php/Connections/connBSM.php' (include_path='.;C:\php5\pear') in C:\wamp\www\dynamic\detail.php on line 1
Office Guy-172461
It looks like you didn't un-zip the downloaded files before using them.
canonman208475
unzip?
I don't know but the other files seem to be okay what do you think I should do??
Office Guy-172461
Maybe this will help:
How_To_Unzip_A_File
The errors you were getting were letting you know that the referenced include files could not be found. You should unzip all of the files into your local site root. Also, you must ensure that you have your site properly defined within DW. Let us know if you have any further problems with the unzipping or accessing the files.
