DD and Mysql Error
Thread begun 12/27/2009 11:44 am by hnewsom391969 | Last modified 1/06/2010 9:47 am by Eric Mittman | 2334 views | 3 replies |
hnewsom391969
DD and Mysql Error
Can anyone help with this error? 0){ while($rowc = mysql_fetch_array($resc)){ echo $rowc[3]; } } ?> $
My site address is our_packages.php
The code for the DD is below:
<tr>
<td colspan="5" bgcolor="#2a2a2a" height="19"><p>
<label for="parent"></label>
<span class="Herman4">Start By Determining Your Business Here:</span></p>
<p>
<label for="child"></label>
<label for="parent2"></label>
<select name="state" id="state" >
$sqlc = "select * from tbl_state order by fld_sname";
$resc = mysql_query($sqlc);
$countc = mysql_num_rows($resc);
if($countc > 0){
while($row = mysql_fetch_array($resc)){
<option value="<?=$row['1']?>">
<?=$row['1']?>
</option>
do {
<option value="<?php echo $row_Parent['fld_id']?>"><?php echo $row_Parent['fld_sname']?></option>
} while ($row_Parent = mysql_fetch_assoc($Parent));
$rows = mysql_num_rows($Parent);
if($rows > 0) {
mysql_data_seek($Parent, 0);
$row_Parent = mysql_fetch_assoc($Parent);
</select>
<select name="bname" id="bname" >
$sqlc = "select * from tbl_bname order by fld_bname";
if($countc > 0){
<?=$row['1']?>
</option>
do {
<option value="<?php echo $row_Child['fld_id']?>"><?php echo $row_Child['fld_bname']?></option>
} while ($row_Child = mysql_fetch_assoc($Child));
$rows = mysql_num_rows($Child);
if($rows > 0) {
mysql_data_seek($Child, 0);
$row_Child = mysql_fetch_assoc($Child);
</select>
<label for="target"></label>
<input type="button" value="Add To List" id="submit1" onclick="get()"/>
<input name="remove" id="remove" onclick="WA_RemoveSelectedFromList(MM_findObj('target'),'|WA|0|WA|',-1,'0','None Selected')" value="Remove" type="button" />
<span id="status"></span>
<label for="add">$</label>
I went to the link specified and the only errors that I could see reported were coming from your css files and there were some missing } curly brackets in there.
I did not see an error on your page relating to the dynamic dropdowns. Please explain a little about the steps you have taken to implement the dropdowns and the result you are getting now and if you had them working before. Also, let us know if you encounter an error exactly what the full error message is and when it occurs for you.
hnewsom391969
Hi Eric,
The missing {'s was good to know. I used the assistance of another developer to recreate my site and he has the drop downs working. On the site I created, I was not able to get them to work correctly. I tried your directions alongwith an adhoc way and was not successful. I appreciate your response to this issue but you can now close this ticket. Speak to you on my next webassist project.
Ok, I'm glad you were able to get the dropdowns working in some fashion. Let us know if you have any other questions or if you encounter any problems.
