Graph order or label...
Thread begun 12/26/2009 11:53 am by scott351953 | Last modified 12/28/2009 10:12 am by Jimmy Wu | 2158 views | 2 replies |
scott351953
I am having an issue with the Dynamic Web Charts... See here for a sample of the page:
pulseScottsdale.php?graphsCat=1
I you look at the progrssion of months, is goes from the most current on the left and the oldest on the right. My client would like this in reverse order. I had placed a ticket on this a while back and could not come up with a solution. Does anyone know how to do this?
Or...
I have a label that says, "most current data on the left" above each graph. If I can not re-order the data he would like to make this in red. I looked at the code and did not see a way to style this. I think this would be the easiest way to go, but either way would be good. Any suggestions would be appreciated!
neilo
This post has been deleted.
Jimmy Wu
If you are getting the dates from a database dynamically, you can sort the results by the date and group them by months.
I'll attach a screen shot of my data setup so you can have a reference.
Jimmy Wu
looks like that is too small to see and is the wrong tab. Here is a larger version of the correct tab:
