How to add up a column of numbers on a search query
Thread begun 12/24/2009 3:01 pm by mel321998 | Last modified 1/03/2010 10:06 pm by Dani Chankhour | 5942 views | 11 replies |
mel321998
Hi Everyone,
Happy Xmas & New Year
Using the search wizard I have set up a simple search to show records from a to and from date and this is working fine
The recordset includes two columns of figures the id's being ' fee ' & ' comm '
I want the search result page to show somewhere at the bottom of the page the totals for
' fee ' & ' comm '
Can this be done on a search results page and if so what code would I need to add. I have a very restricted knowledge of
php and mysql although I suspect that the the SUM statement comes into play some how and an echo statement for the result?
Thanks for your help
Mel
Pro Covers FX
adding columns
Hi Mel,
With out seeing the code of the page it is a little hard, but I will give it a try. There should be a for loop that is reading the records from your database in this for loop you would want to use two php variables say $fee and $comm add the column value to these variables each time trhought the for loop then after the for loop you should be able to use php to echo them out on the screen.
Enjoy
Pro Covers FX
P.S. if this does not help post you code and I should beable to get it working for you.
mel321998
Roy Neuf
Not sure what to do, here is page code have put the code in a zip file as submission error coming up
"The text that you have entered is too long (14939 characters). Please shorten it to 10000 characters long"
Here is zip
Dani Chankhour
To get the total for those two columns, update your query from:
SELECT recordNumber, date, fName, lName, telNo, apptTime, lenghtAppt, fee, comm, comments FROM thenumbers ORDER BY date DESC
to
SELECT recordNumber, date, fName, lName, telNo, apptTime, lenghtAppt, fee, comm, comments, SUM(fee) as Tfee, SUM(comm) as Tcomm, FROM thenumbers ORDER BY date DESC
This should add two columns to your record set. You could then drag the binding of those tow columns to any where on the page.
mel321998
Hi Dani,
Thanks for your reply,
Now getting this error with and without your additional code for totalling columns
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'FROM thenumbers WHERE (date >= "2009-12-01 00:00:00") AND (date <= "2009-12-28 2' at line 1
I am running this offline on WAMPServer with MYSQL Ver 5.1.32 for testing berfore going live
The odd things is that 3 days ago the search form was working but not adding up the totals now I am getting this error
But nothing has been changed or updated on my laptop or WampServer ?
Mel
Dani Chankhour
Sorry, it looks like i have a syntax error in my sql statement, please change it to:
SELECT recordNumber, date, fName, lName, telNo, apptTime, lenghtAppt, fee, comm, comments, SUM(fee) as Tfee, SUM(comm) as Tcomm FROM thenumbers ORDER BY date DESC
You could see that i removed a comma before "FROM"
mel321998
Hi Dani,
The records are now showing again but when I add the additional code you supplied, instead of displaying 7 records that fall into the date search range it is only displaying 1
I tried taking out the ORDER BY date DESC just as a test but it still is only returning one record
Is it because the the two new fields Tfee & Tcomm are not being echoed anywhere by me on the results page as yet?
If so should they take the form of something like this
<?php echo($row_WADAthenumbers['Tfee']); ?>
<?php echo($row_WADAthenumbers['Tcomm']); ?>
Thanks Mel
Dani Chankhour
It looks like because it is a search record set, it is adding a Group By clause which could cause this issue. We can try this differently. Please change the query back to the way it was, and instead add this block of code:
$fee = 0;
$comm = 0;
$fee += $row_WADAthenumbers['fee'];
$comm += $row_WADAthenumbers['comm'];
under this line:
<?php do { ?>
and then under this line:
<?php } while ($row_WADAthenumbers = mysql_fetch_assoc($WADAthenumbers)); ?>
add:
echo "".$fee."";
echo "".$comm."";
mel321998
Hi Dani,
It is now displaying the correct amount of records but not adding up the runing totals for the fee & comm it is just displaying the first fee and comm total
in the
echo "".$fee."";
echo "".$comm."";
Fields
Mel
Dani Chankhour
I have opened a support ticket to further assist you:
