adding an upload field question
Thread begun 12/24/2009 7:47 am by i.edwards384429 | Last modified 12/28/2009 1:17 pm by Dani Chankhour | 1420 views | 3 replies |
i.edwards384429
HI
just running through the "adding digital file pro to dataassist insert .....etc etc
I followed the instructions Ok until I reached the section:
Updating the insert record server behaviour.
IN the server behaviours panel I only have five instances of WA Upload Files (userImage1) up to 5 which are the upload fields I added.
Item 17 in the help file says
from the servers behaviours panel, double click on the INSERT RECORD OPTION
If I press the + sign I do see an option to Insert a record but I suspect this is not the thing I want because it appears with a single click and when it does I see no "next" button.
Do tell what am I missing?
thanks
Ian
Dani Chankhour
The insert record server behavior, should be the DataAssist Insert Record Server Behavior not the Digital File Pro server behaviors.
i.edwards384429
update
Hi
trust you had a good break, thanks for the assist.
cheers
Ian
Dani Chankhour
Yes. I'm glad i was able to help.
