IE7 Viewing Problem
Thread begun 12/24/2009 6:34 am by drubin312804 | Last modified 12/28/2009 9:27 am by Jimmy Wu | 4194 views | 6 replies |
drubin312804
IE7 Viewing Problem
The Home of the Following site works fine in FireFox, but in IE7 the lower right image get pushed below the page.
designer_sign/
I've tried some resizing things, but nothing seems to work. Any suggestions?
neilo
Try adding: align="top" to line 109 of your page code:
<div id="content"><img src="images/home_pix/bottom_img.jpg" alt="" width="665" height="302" border="0" align="top"/></div>
drubin312804
Originally Said By: neilo
Thanks for the suggestion, I tried it, but I still have the same results.
drubin312804
Originally Said By: drubin312804
I've also created a page called index_2.html
with no omage in the content div. As you can see in IE7 it still does not work correctly. Again FireFox is fine.
neilo
Right, in your screen.css, make your content div 660px wide instead of 665,
#outerWrapper #contentWrapper #content {
background-image: url(../DesignerSignHomePage_HomePage1_images/home_background0.gif);
background-repeat: no-repeat;
margin-left: 236px;
width: 660px;
height: 305px;
background-color: #4BA6DE;
(and you will need to resize your bottom_img.jpg image width to equal to or less than 660px too)
drubin312804
margin-left: 236px;
width: 660px;
height: 305px;
Yep, that did the trick. Thank you very much. I have to say I love your products, but I love this support forum even more.
Jimmy Wu
In IE, if the width of the containing div is too small, the contents will be pushed below. In the future, if you see inconsistencies between the browsers like this, you should check the width of the containing div. In the other browsers, it will show up the way you intended.
