HTML Editor and CSS
Thread begun 12/24/2009 1:55 am by richard.abitbol263730 | Last modified 12/28/2009 11:26 am by Dani Chankhour | 2440 views | 4 replies |
HTML Editor and CSS
After trying to change the "styles" in HtmlEditor, the page where the editor is only shows "Red Title" as styles instead of the styles in the stylesheet I tried to connect.
Pse advice
Pro Covers FX
Styles
There is info on this in the Editors manual, under the Style Tab.
Explains how to add styles to the editor.
Enjoy
Pro Covers FX
Dani Chankhour
Could you explain how you went about adding to the styles drop down menu.
You should be able to add by clicking the Customize button from the Quick Insert and then Click on the Styles tab where you can browse to your style sheets and select which class to add to the styles drop down.
JeanM
how do i remove "Red Title" from my styles list? i would prefer to just alter my styles.xml file, but it is not in there. is it someplace else i can remove it w/o having to go back into the wizard? whenever i go back into the wizard, i get all kinds of strange anomolies that take me a long time to fix.
Dani Chankhour
To Remove the Red Title class from the Styles drop down, open the fckconfig.js file which is located under the HTMLEditor folder and replace this code:
FCKConfig.CustomStyles =
'Red Title' : { Element : 'h3', Styles : { 'color' : 'Red' } }
with
In regard to your second question, you will need to reenter the wizard and select your css file in order for the editor to create your styles xml file.
If you are having issuing reentering the wizard then you will need to create the styles xml file manually and also edit the js file under your custom folder to reference your css and xml file.
