Results Page MySQL error for Price Range Search after ORDER BY mod
Thread begun 12/23/2009 1:29 pm by Infotraveler | Last modified 1/04/2010 1:41 pm by Jimmy Wu | 4306 views | 6 replies |
Infotraveler
I have followed your directions for ordering product results (on the Product_Results.php page) from forum post: showthread.php?t=2077 . The results do get listed in alphabetical order. However; when I use the search form and search for a price range, I get the following error back:
"You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'HAVING (ProductPrice >= 10) AND (ProductPrice <= 3000) LIMIT 0, 5' at line 1"
Any suggestions to fix this ?
Thank you,
Steve
You are using bad SQL for a price range search:
should be:
WHERE (ProductPrice >= 10) AND (ProductPrice <= 3000)
Infotraveler
Using PowerStore SQL
Thank you for your quick response and your recognition of the error cause. I am using the Product_Results.php page that comes with PowerStore 2. The only change was to add in the "ORDER BY products.ProductName ASC" at the end of the query string starting at line 155. I added this in based on the forum post referenced in the original message.
How do I fix the SQL in the PowerStore 2 provided page ?
Thank you,
Steve
I have opened you a ticket on this issue so that we can look into the problem further. Please login to WebAssist.com and visit your support history to update the ticket.
Jimmy Wu
The query to get this to work should look like this:
mysql_select_db($database_localhost, $localhost);
$query_WADAProducts = "SELECT *, (ProductStock - (SELECT Coalesce(Sum(DetailQuantity),0) FROM orderdetails INNER JOIN orders ON OrderID = DetailOrderID WHERE DetailProductID = ProductID AND OrderDate > ProductUpdateDate)) AS NumLeft, (SELECT MAX(ProductPrice) FROM products as prod2 INNER JOIN productoptions ON productoptions.ProductID = prod2.ProductID WHERE productoptions.GroupingID = products.ProductID AND prod2.ProductLive <> 0) AS TopPrice, (SELECT MIN(ProductPrice) FROM products as prod2 INNER JOIN productoptions ON productoptions.ProductID = prod2.ProductID WHERE productoptions.GroupingID = products.ProductID AND prod2.ProductLive <> 0) AS BottomPrice FROM products LEFT OUTER JOIN productcategories ON ProductCategoryID = CategoryID WHERE ProductLive <> 0 AND COALESCE((SELECT GroupingID FROM productoptions WHERE productoptions.ProductID = products.ProductID LIMIT 1), ProductID) = ProductID";
setQueryBuilderSource($query_WADAProducts,$WADbSearch2,false);
setQueryBuilderSource($query_WADAProducts,$WADbSearch1,false);
$query_WADAProducts.= preg_replace("/ AND /", " HAVING ", $WADbSearch2->whereClause, 1);
$query_limit_WADAProducts = sprintf("%s %s LIMIT %d, %d", $query_WADAProducts, " ORDER BY ProductPrice ASC", $startRow_WADAProducts, $maxRows_WADAProducts);
$query_WADAProducts.= " ORDER BY ProductPrice ASC";
$WADAProducts = mysql_query($query_limit_WADAProducts, $localhost) or die(mysql_error());
$row_WADAProducts = mysql_fetch_assoc($WADAProducts);
The HAVING clause cannot be after the ORDER BY clause, which was causing an error.
Infotraveler
If you want to ORDER BY other fieldnames
Thanks go to Jimmy and the WebAssist engineering staff for solving this SQL issue.
By the way, it may be obvious but, if one wants to ORDER BY ProductName so that the product get listed alphabetically in ascending order (which was what I wanted to do ), then just replace the ProductPrice with ProductName in the ORDER BY additions.
Steve
Jimmy Wu
Thanks for the input. If you run into any additional issues, feel free to open a new thread.
