Linkpoint
Thread begun 12/23/2009 8:50 am by cchesnet148148 | Last modified 1/04/2010 5:17 am by cchesnet148148 | 5774 views | 12 replies |
cchesnet148148
Linkpoint
I set up the checkout wizard to use Linkpoint API, entered our store number.
I am using the test cc #'s from linkpint 4111111111111111
it just goes to the failure page, i posted the binding for local check out response and it is black but Full request is there.
what do i need to do to make sure the data is being sent.
Jimmy Wu
What is the full request that is being sent to LinkPoint?
cchesnet148148
1001114983staging.linkpt.net1129SALELIVE00772.2772.20 4111111111111111121260087.6858NUNSPECIFIED2f0d92ed39a29dfa299d6a7e82c067d8S-E13610-08-A11/2" Silco Sleeve Knit/11.43500S-E13610-08-A11/2" Silco Sleeve Knit/11.43100
The response may not be blank... it may just be XML, which won't show unless you view the source code.
Try looking there and see if that sheds some light on the problem.
cchesnet148148
source code - (using chrome)
<p class="eC_OrderInfo"><order><merchantinfo><configfile>1001114983</configfile><keyfile></keyfile><host>staging.linkpt.net</host><port>1129</port></merchantinfo><orderoptions><ordertype>SALE</ordertype><result>LIVE</result></orderoptions><payment><tax>0</tax><shipping>0</shipping><subtotal>772.2</subtotal><chargetotal>772.20</chargetotal></payment><billing><name> </name><address1></address1><address2></address2><city></city><state></state><zip></zip><country></country><phone></phone><fax></fax><email></email></billing><creditcard><cardnumber>4111111111111111</cardnumber><cardexpmonth>12</cardexpmonth><cardexpyear>12</cardexpyear><cvmvalue></cvmvalue></creditcard><shipping><items>600</items><weight>87.6</weight><total>858</total></shipping><transactiondetails><taxexempt>N</taxexempt><terminaltype>UNSPECIFIED</terminaltype><oid>2f0d92ed39a29dfa299d6a7e82c067d8</oid></transactiondetails><items><item><id>S-E13610-08-A1</id><description>1/2" Silco Sleeve Knit/1</description><price>1.43</price><quantity>500</quantity></item><item><id>S-E13610-08-A1</id><description>1/2" Silco Sleeve Knit/1</description><price>1.43</price><quantity>100</quantity></item></items></order></p>
<p class="eC_OrderInfo">-----------------------------</p>
<p class="eC_OrderInfo"></p>
<p class="eC_OrderInfo">--------------------------------</p>
the end should show the response between the lines...
I opened up a support incident to help you look into this further. I see the keyfile setting is blank, that might be part of it, but you should be getting some sort of error in a response no matter what, so I think we should have someone help you debug it.
cchesnet148148
ok, i uploaded the files that were requested... is support working this week?
Jimmy Wu
Jason is out for the week and he will be taking a look at your issue. Sorry for the delay.
cchesnet148148
ok, think i found the problem...
on the confirm.php page there is an if statment that triggers the linkpoint api:
if (($_SERVER["REQUEST_METHOD"] == "POST") && (isset($_SERVER["HTTP_REFERER"]) && strpos(urldecode($_SERVER["HTTP_REFERER"]), urldecode($_SERVER["SERVER_NAME"].$_SERVER["PHP_SELF"])) > 0) && isset($_POST)) {
... lots of lp code ...
$WAGatewayResponse = LinkPointAPI_Post($LinkPointAPI_required,$LinkPointAPI_itemized,$LinkPointAPI_optional);
echo $WAGatewayResponse;
if ($WAGatewayResponse) {
$FS2010->redirStr = "checkout_success.php";
else if ("checkout_failure.php" != "") {
header("Location: ". "checkout_failure.php");
exit();
the page that keeps show on my end is: checkout_failure.php
how can i test to see why it keeps going to the else if?
Jimmy Wu
you can make use of the die statement. Put something like die("In else if"); in the else if and a similar die statement like die("In if"); in the if section. The die statement will print out to the page the string that you specify and stop execution of the rest of the page.
