shipping of each unique item separately?
Thread begun 12/22/2009 2:58 pm by sam308940 | Last modified 1/05/2010 7:58 am by Ray Borduin | 3810 views | 5 replies |
sam308940
i have shipping setup on a quantity basis.
0-100 = X
100-200 = Y
201-300 = Z
i need to figure out how i can setup shipping so that each UNIQUE item is calculated to ship individually.
Meaning if i have ...100 of itemA and 200 of itemB
i want the shipping to be X+Y (total to ship 100 + total to ship 200)
NOT Z (total to ship 300)
how can i do this?
I have shipping based on QUANTITY, ZONE(based on state), and TYPE (ground, express)
here is the code from 1 shipping definition.
//eCart Rule
function WAEC_pcccart_Ship1_1_150() {
$totalShipping = 0;
if (true && (($this->TotalColumn("Quantity") > 10) && ($this->TotalColumn("Quantity") < 150) && ((isset($_SESSION['ship_stg'])?$_SESSION['ship_stg']:"") == "1") && ((isset($_SESSION['ship_method'])?$_SESSION['ship_method']:"") == "1"))) {
$totalShipping += 10;//Result
return WA_eCart_FormatNumber($totalShipping, $this->ForceDecimalsC, $this->DecimalPlacesC);
//eCart Rule
THANKS for any help
Sam
You would probably have to use both Calculation columns and rules in order to accomplish this.
Do you have a grid of shipping to be charged in every case? If I could look at that I might be able to help you with the formulas you would need.
How many zones do you have? Make sure to include the session variable names and what they will contain for the various zones and types and I can probably help you write the necessary formulas.
sam308940
Thanks Ray! (HAVE A GREAT HOLIDAY)
I have the shipping grid in visual format:
card_pop.php?I=SH
there are 3 shipping methods, 6 zones, and 3 qty groups
(not all zones have all shipping methods)
Im attaching the current cart include file - it shows all the shipping options
because of the amount of shipping options, i created 2 of them and from there copied/pasted/handcoded the rest. if you have shorter ways to code (and eliminate shipping rules) please do!
to follow my shipping rules naming logic ill explain 1 of them...
Ship Group #, Method, Max Qty
Ship1_1_150 : this is shipping group 1, method 1(ground), qty <150
on the view cart page: i have a few sessions i create
(im attaching the file)
ship_st - state shipping to (selected on view cart before update or checkout can be submitted)
ship_stg - shipping group (zone). (1-6 in the order show in shipping link)
ship_method - Ground = 1, Priority=2, Express=3 (by default its set to 1)
note - some ZONES dont have some methods.
I have duplicated things to cover any errors occuring.
zones 5/6 do no have 1(ground), method 2 is duplicated as 1
zone 1 only has ground, so i duplicated 1 as method 2/3.
zone 2 doesnt not have 2(priority), so 1 and 2 are the same here.
Thanks in advance for your help!
sam
OK... with this many options I would probably put them into a multi-dimensional array in php and then write a function to return the result. Then I'd add that function to every page that has the cart and refer to it in the calculation.
Unfortunatly I don't have time to do it for you right now and I'm on vacation starting in about an hour until Jan. 4.
Maybe someone else can help you in the meantime, if not I'll try helping when I return.
sam308940
Ray - its no problem about Jan 4. Im gone pretty much till then too!
OK, here is your shipping charges expressed in a php function:
function getShipCharge($cartQuantity) {
$shipZone = isset($_SESSION['ship_stg'])?$_SESSION['ship_stg']:1;
$shipMethod = isset($_SESSION['ship_method'])?$_SESSION['ship_method']:1;
if ($cartQuantity < 100) { // 1-99 cards purchased
switch ($shipZone) {
case 1: // CT, DE, MA, ME, NH, NJ, NY, PA, RI, VT
switch ($shipMethod) {
case 1: // UPS Ground
return 10;
break;
break;
case 2: // DC, MD, NC, OH, SC, VA, WV
return 15;
break;
case 3: // USPS Express
return 30;
break;
break;
case 3: // AL, FL, GA, IA, IL, IN, KY, MI, MN, MO,TN, WI
return 15;
break;
case 2: // USPS Priority
return 18;
break;
return 35;
break;
break;
case 4: // AK, AR, AZ, CA, CO, HI, ID, KS, LA, MS, MT, ND, NE, NM, NV, OK, OR, SD, TX, UT, WA, WY
return 15;
break;
return 18;
break;
return 42;
break;
break;
case 5: // United Kingdom & Ireland
return 35;
break;
return 45;
break;
break;
case 6: // Canada
return 28;
break;
return 42;
break;
break;
} else if ($cartQuantity < 150) { // 100 - 149 cards purchased
return 10;
break;
break;
return 15;
break;
return 42;
break;
break;
return 15;
break;
return 18;
break;
return 45;
break;
break;
return 15;
break;
return 22;
break;
return 48;
break;
break;
return 45;
break;
return 55;
break;
break;
case 6: // Canada
return 30;
break;
return 45;
break;
break;
} else { // 150 or more cards purchased
return 12.5;
break;
break;
return 15;
break;
return 45;
break;
break;
return 15;
break;
return 20;
break;
return 52;
break;
break;
return 15;
break;
return 25;
break;
return 52;
break;
break;
return 55;
break;
return 65;
break;
break;
case 6: // Canada
return 35;
break;
return 55;
break;
break;
return 0;
If you either add that code to an include file, or add the code itself, and put in on every page that has an ecart object on it.
Then go to the cart object definition Calculations tab and add a calculation that uses this function like:
RowShipping = getShipCharge([Quantity]);
Then you can create a single shipping rule to charge the total column value of the RowShipping calculation created.
