What does the CSS Scupltor commented out code do?
Thread begun 12/22/2009 9:45 am by keithlogan347721 | Last modified 12/23/2009 4:02 pm by keithlogan347721 | 4258 views | 6 replies |
keithlogan347721
Hi
I'm using CSS Sculptor for the first few times. I notice that it generates the following commented out code/ What does it do exactly?
Thanks!
<!--[if IE 5]>
<style type="text/css">
/* IE 5 does not use the standard box model, so the column widths are overidden to render the page correctly. */
#wrapper #content #leftColumn {
width: 263px;
#wrapper #content #rightColumn1 {
width: 215px;
</style>
<![endif]-->
<!--[if IE]>
/* The proprietary zoom property gives IE the hasLayout property which addresses several bugs. */
#wrapper #content, #wrapper #content #content2 {
zoom: 1;
</style>
<![endif]-->
<!--[if lt IE 7]>
img, div {
behavior: url("../Website/CSSSculptor/3ColumnFixedHeaderandFooter_CaboSunset_images/iepngfix.htc");
</style>
It is there to address problems in various version of IE.
IE is not a very standards compliant browser, it has many quirks in rendering CSS that need to be accounted for in order for the menus to display in IE the same as they do in other browsers.
This portion is addressing box modal issues in IE5:
<!--[if IE 5]>
width: 263px;
width: 215px;
</style>
<![endif]-->
this porting is addressing several issues across all version of ie:
<!--[if IE]>
zoom: 1;
</style>
<![endif]-->
this portion is addressing a problem with transparent images in ie6 and below:
<!--[if lt IE 7]>
img, div {
</style>
keithlogan347721
Thanks.
The code:
'this portion is addressing a problem with transparent images in ie6 and below:
<!--[if lt IE 7]>
img, div {
</style>'
The url link that is generated, I have changed the location of the iepngfix.htc - do I need to manually update this link?
yes, you will need to manually change the link if you move that file.
keithlogan347721
So I've basically moved the 'iepngfix.htc' into the following location from the root of the site 'css/css_images/iepngfix.htc'
So should the code look like this?
<!--[if lt IE 7]>
img, div {
behavior: url("css/css_images/iepngfix.htc");
</style>
<![endif]-->
Is there a way to test if I have this in the correct location?
the path is document relative. The correct path depends on the location of the page on your server.
If the page this css is on is at the root of the site:
somepage.htm
and the iepngfix.htc file is in the css/css_images folder off the root of the site:
iepngfix.htc
then yes, that is the correct code.
If you load the page in FireFox, and view source, links to css, js and image files are clickable, you can test if the path is correct by clicking the link to the iepngfix.htc file in source view, if the path is not correct, you will get a 404 page not found error.
keithlogan347721
Hi Jason,
Thanks for confirming this.
Merry Christmas!
