Paypal button does not open in new tab when target set to _blank
Thread begun 12/22/2009 9:28 am by forgottenglory205659 | Last modified 2/05/2010 2:35 pm by purchase400319 | 29287 views | 3 replies |
When the Paypal button is clicked, I want it to open the Paypal checkout in a new tab. The code I have for the button is as follows:
<input type="submit" class="buy" name="submit" value="BUY NOW" target="_blank" />
The class formats the button through CSS. I added a target of _blank to either open in a new window or tab, depending on the user's settings. However, when I test the page in IE8 and Firefox 3.0, the Paypal checkout loads in the same tab. It only opens in a new tab in Opera.
I remember that target attribute set to _blank use to work well in older versions of the extension.
My page is encoded in XHTML 1.0 Strict.
Can you please tell me what I need to do to get the checkout to open in a new tab/window.
you cannot use traget="_blank" on the submit button, you have to use it on the form tag:
<form name="form1" method="post" action="somepage.php" target="_blank"">
Thanks! It works like a charm! ;-)
purchase400319
Open in new tab/window when target set to "_blank"
Oops, Jason, you added an extra quotemark : target="_blank"">
Anyway, this does not work on my form.
<Form Method="Post" Action="https://ssl.hostingplatform.com/homelink.ca/cgi-bin/Rentform.pl" target="_blank">
Instead, I had to add the target to the initial referring link:
<a href="https://ssl.hostingplatform.com/homelink.ca/Rentform.htm" target="_blank">
RESULT : New window in MSIE8, new tab in Firefox3.5
