What happened to my Image
Thread begun 12/21/2009 12:42 pm by joneil375464 | Last modified 1/19/2010 5:55 pm by Jimmy Wu | 7699 views | 13 replies |
joneil375464
Using godaddy as host
Using webformmailer.php 2.0 to handle forms
Dreamweaver CS4
RWC permissions set
Irite 1.03
$Config['Enabled'] = true ;
$Config['UserFilesPath'] = '/userfiles/' ;
$Config['UserFilesAbsolutePath'] = '' ;
Image appears in the form but when I check the e-mail form the image is not in the form. There is no reference to an image.
Everything on the form appears except the image.
What is going on?
Jimmy Wu
Do you have a link to a site that I can see this issue on?
How are you creating the email? Was it using Universal Email? What is the path that is referenced by the image in the html editor window?
joneil375464
Originally Said By: Jimmy Wu
It is a simple contact form, I am not using css form builder.
base HREF = image
Link to site is ContactUs.php
Help would be appreciated,,,, Fustration is setting in.
shadow329043
What are you using to send the mail - do you have the image referenced in the configuration file that creates and send your email?
Shadow
joneil375464
Originally Said By: shadow329043
Shadow
Just using standard script.
Is there suppose to be script to reference the image? If so where would it be located?
Jimmy Wu
I'm not seeing a file upload button on the page you referenced. Is the image referenced from another location or is it one that is uploaded through the editor?
joneil375464
Gave up
I gave up on trying to figure this thing out.
I upgraded and purchased HTML Editior, now let me see if this version will work. I am installing the upgrade now....
fingers crossed!
Jimmy Wu
Hopefully the setup will work for you. It should be a simpler process to setup uploads on HTML editor compared to iRite.
joneil375464
Still no image in form mail
Jimmy,
The image now on the server but it is not in the form mail.
What is going on, getting past the point of fustration. There is no indication that an image was sent with this email
Jimmy Wu
Can you send me the source for the email that you received? Is the image url getting added to that code?
In the html editor instance, after writing the contents, hit the code button and also copy that, paste it in to a text file and attach it here.
