Align sub menu to right of parent
Thread began 12/21/2009 5:17 am by Chris_Goodiel | Last modified 1/08/2010 12:13 pm by Eric Mittman | 1740 views | 3 replies |
Chris_Goodiel
Hi I was wondering if there is a way to align the sub menus to the right of the parent.
My last menu item is up against the right side of my container div and the submenu items text are wider than the parent items so with the alignment set to the left(standard) it passes the edge of my container div.
Thanks for your time,
Chris
You can adjust the sub menu levels like this by adjusting the padding on the item within the edit design interface. When you edit design choose the level of the menu you are working with and click on the item tab. In here you can uncheck the box that applies equal margin to all then you can specify your own margins for left are right to get the submenu positioned just where you would like it. If you need to get it further to the left you can set a negative value for the left margin.
If you have any further questions about this please let us know and include any other details you can, a screen shot might be helpful.
Chris_Goodiel
is this an issue when viewing in different Operating systems and font resolution?
So if I have a font set to say 16 pixels and the submenu set to have padding on either side to be 10 pixels with this show different placement from a Mac browser to a Windows Browser?
The things that will make the same settings display differently are the browser being used to view the page and possibly the DPI settings on the OS.
For example if you use FireFox you should see the same result weather you are using it on a Windows machine or on a Mac. If your DPI settings were not standard then you may see this page a little differently. The default is 96dpi. This setting should be pretty consistent between different machines though.
