image paths
Thread begun 12/20/2009 2:00 pm by i.edwards384429 | Last modified 12/21/2009 12:21 am by i.edwards384429 | 2553 views | 2 replies |
i.edwards384429
image paths
Hi
my wa globals is
$WAGLOBAL_Root_URL = "http://www.xm496.com" ; //Absolute path to your site folder.
$WAGLOBAL_Site_Name = "XM496 Admin" ;
$WAGLOBAL_localRoot = "/PowerCMS/"; //relative path to your PowerCMS files on your local testing server.
$WAGLOBAL_remoteRoot = "/PowerCMS/"; //relative path to your PowerCMS files on your remote server.
//iRite Images upload settings
$WAGLOBAL_Images_Folder = "/PowerCMS/images/"; //relative path to your images folder.
$WAGLOBAL_Swf_Folder = "/PowerCMS/swf/"; //relative path to your swf folder.
// Admin Settings
$WAGLOBAL_Admin_UserName = "****r" ;
$WAGLOBAL_Admin_Password = "****" ;
When I add an image by using the browse tab after uploading the path is shown as
In reality the file is uploaded to
So it's creating an additional PowerCMS directory
I know it's a path error but can't work it out. Of course the file is not shown in the preview window or on the page unless I manually copy it to
images/
Any ideas which path is wrong?
thanks
Ian
neilo
These should be your settings if your cms files and folders reside in 'PowerCMS' folder in the root directory:
$WAGLOBAL_Root_URL = "http://www.xm496.com/PowerCMS/" ; //Absolute path to your site folder.
$WAGLOBAL_Images_Folder = "images/"; //relative path to your images folder.
$WAGLOBAL_Swf_Folder = "swf/"; //relative path to your swf folder.
// Admin Settings
Also make sure you have applied the fix available from your WebAssist Downloads Page (select the PowerCMS link, click on 'Known Issues' and download the 'PowerCMS: Support Fix - Image upload from the Upload tab does not work' zip file. Follow the instructions contained in it.
i.edwards384429
update
Hi
thanks, I'll try that later - on site for most of the day
cheers
Ian
