centred fixed footer ?
Thread begun 12/20/2009 12:07 pm by CraigR | Last modified 12/21/2009 1:37 pm by neilo | 2882 views | 4 replies |
CraigRBeta Tester
using css sculptor to start me off, i have created a nice 2 column layout with a full width header and a fixed footer, ie the footer sits nicely at the bottom of the page.
at the moment, the footer is full width
is there a way in which i can make it the same width as the content wrapper and centred, yet remain anchored at the bottom of the page ?
neilo
Hi Graig,
When you're creating the design in CSS Sculptor, you wold just choose 'fixed normal' instead of 'fixed full width'.
But to adjust an existing one, you would need to add a width property to the footer div, and add auto right and left margins.
Supposing your outer wrapper has a width of 88em, then you would adjust the #fixedFullWidthFooter css to read:
#fixedFullWidthFooter {
margin-top: -17px;
position: relative;
width: 88em;
margin-right: auto;
margin-left: auto;
CraigRBeta Tester
thanks again Neilo.
yet another CSS problem youv'e solved for me.
ps i just noticed this thread is in the wrong section :o
Thank you for the contributions you have been making here on the forums neilo, your css skills and tactics are very helpful and much appreciated.
neilo
Many thanks for that, Eric. But I do get vastly more out the forum than I put in, so thanks right back at you!
